I can´t install OpenMV in Raspbian Jessie
Juanjo120
Postby Juanjo120 » Wed Oct 03, 2018 5:06 pm
I am new using my OpenMV M7 Camera, I just bought it a week ago. I would like to use it with my Raspberry pi 3 Model B, the OS is Raspbian Jessie. The tutorial installation from github doesn't work. The files are downloaded in my SD Card with the cmd in Raspbian, but when I use the command "./make.py --rpi <path-to-qtrpi-installdir e.g. /opt/qtrpi/raspi/qt5>" the error is:
bash: syntax error near unexpected token `newline'
Re: I can´t install OpenMV in Raspbian Jessie
Postby kwagyeman » Wed Oct 03, 2018 7:28 pm
Hi, we have a pre-built version of the IDE here: https://openmv.io/pages/download
The Pi can't actually build the IDE for various reasons.
Juanjo120
Postby Juanjo120 » Thu Oct 04, 2018 11:43 am
I actually tried this version, but it doesn't work. I have some errors running the OpenMV IDE with openmvide.sh.
error while loading shared libraries: libExtensionSystem.so.1: cannot open shared object file: No such file or directory
Postby kwagyeman » Thu Oct 04, 2018 11:52 am
Hi, can you just run the IDE directly by clicking on the binary versus the .sh file? "./openmvide"
Juanjo120
Postby Juanjo120 » Thu Oct 04, 2018 12:02 pm
I have no response from the IDE. In the terminal is the same error.
Postby kwagyeman » Thu Oct 04, 2018 12:32 pm
Hi, is that file located in:
"openmvide install dir"/lib/qtcreator/
? It should be right there.
Juanjo120
Postby Juanjo120 » Thu Oct 04, 2018 1:12 pm
It is right there but just "libExtensionSystem.so.1.0.0"
Is it a problem with different names?
Postby kwagyeman » Thu Oct 04, 2018 9:02 pm
Mmm, could be. You could try renaming the file. Not really sure what's wrong however. I don't have a way to reproduce this issue on my side.
Users browsing this forum: MSN [Bot] and 10 guests
