Openmv 2.0.0 Firmware 3.0.0 no framebuffer display
MLCMichaelLamber
Postby MLCMichaelLamber » Wed Aug 08, 2018 2:08 pm
hello,
I have made today an update to openmv 2.0.0 and firmware 3.0.0 (cam m7).
It is not possible to see the frame buffer in the display.
On all other IDE I get the frame buffer.
Michael
Re: Openmv 2.0.0 Firmware 3.0.0 no framebuffer display
Postby kwagyeman » Wed Aug 08, 2018 2:55 pm
Hi, is the frame buffer disabled?
MLCMichaelLamber
Postby MLCMichaelLamber » Thu Aug 09, 2018 1:17 am
Do you mean in the IDE?
In the IDE tehe frame buffer is enabled.
Is there an other way to enable the frame buffer?
Michael
Postby kwagyeman » Thu Aug 09, 2018 2:09 am
Okay, can you give some more information for me to reproduce?
We haven't seen this error before. As far as I know the current IDE works fine.
Screen shots?
MLCMichaelLamber
Postby MLCMichaelLamber » Thu Aug 09, 2018 2:27 pm
how can I attached the screenshot?
When I will add files (pdf, jpg, bmp). I get the info "invalid file extension"
Info:
OpenMV IDE 2.0.0 (german)
Firmware 3.0.0 cam m7
OS Windows 10 Professional 64 bit
When I connect the cam serial monitor works.
In the framebuffer I see the message "kein Bild" (no picture)
All text is in german.
I change the language from german to english.
The framebuffer did not function.
Michael
MLCMichaelLamber
Postby MLCMichaelLamber » Thu Aug 09, 2018 2:37 pm
Program:
# Hello World Example
    print(clock.fps())              # Note: OpenMV Cam runs about half as fast when connected
oelalfey
Postby oelalfey » Thu Aug 09, 2018 3:46 pm
Please make sure the framebuffer is Not disabled.
Postby kwagyeman » Fri Aug 10, 2018 1:32 pm
Question, do you get text output on the serial terminal when you run the program and does the Green arrow switch to a red stop button?
MLCMichaelLamber
Postby MLCMichaelLamber » Mon Aug 13, 2018 2:43 pm
Yes I get data in Serial output Windows.
Frame Buffer is enabled.
THANKS
MICHAEL
MLCMichaelLamber
Postby MLCMichaelLamber » Mon Aug 13, 2018 2:45 pm
Yes The Greenpeace Button Switched To Red one
Postby kwagyeman » Mon Aug 13, 2018 6:10 pm
Mmm, I don't know what the problem is. Um... Is there any physical damage to the camera lens system? Can you check that the lens cap is not on, the lens is mounted well, there's no tape on the camera see sensor, etc? The IDE will generate errors if it's unable to pull images from the camera... So, the input image data has to be broken.
Postby iabdalkader » Mon Aug 13, 2018 6:52 pm
Using color bars mode should help narrow down the issue:
sensor.set_colorbar(True)
Users browsing this forum: MSN [Bot] and 3 guests
