MemoryError when read wave frames
Falong
Postby Falong » Tue Jun 05, 2018 11:04 pm
when using openMV DAC to play wav file, MemoryError exception is raised in chunk.py when readframes function in wave.py module is called.
I got the chunk.py and wave.py and test wav file from below article:
https://docs.micropython.org/en/latest/ ... _skin.html
the tested wave file is near 9KB, 8-bit, 16KHZ.
def play(filename):
f = wave.open(filename, 'r')
total_frames = f.getnframes()
framerate = f.getframerate()
for position in range(0, total_frames, framerate):
f.setpos(position)
dac.write_timed(f.readframes(framerate), framerate)
delay(1000)
Is this MemoryError due to limited heap size? how to check how much heap available? the tested wav file is less than 9kB.
is there anyone succeed in play wav file with openMV?
-Falong
Re: MemoryError when read wave frames
Postby kwagyeman » Tue Jun 05, 2018 11:53 pm
Hi, I see no reason why this doesn't work. However, we've never tested this.
Can you give use the exact line of code that error happened on?
Falong
Postby Falong » Wed Jun 06, 2018 7:22 am
Please see the attached screenshot.
-Falong
Postby iabdalkader » Wed Jun 06, 2018 11:49 am
import gc
print("Free: %dKBs"%(gc.mem_free()//1024))
Note memory could be fragmented.
Please share the whole script(s)+wave file(s) in a .zip and I'll test them.
Falong
Postby Falong » Thu Jun 07, 2018 8:21 pm
Can you please leave me your mail address, I'll mail you the script.
Also find when wav file is very small(tested with 1KB), it is ok.
-Falong
Postby kwagyeman » Thu Jun 07, 2018 8:46 pm
OpenMV at OpenMV . io
Postby iabdalkader » Sat Jun 09, 2018 4:14 pm
This is just a fragmented memory issue, the scripts run fine on H7. I think most of memory is consumed by just loading/parsing/compiling the modules wave and chunk.
This seems to fix it:
            frames = f.readframes(frame_rate)
            self.dac.write_timed(frames, frame_rate)
            del frames
            delay(1000)
            gc.collect()
Postby kwagyeman » Sat Jun 09, 2018 5:13 pm
Are you on an M4?
Falong
Postby Falong » Mon Jun 11, 2018 10:16 pm
It's on M7.
-Falong
Falong
Postby Falong » Tue Jun 12, 2018 7:01 pm
            del frames
            delay(1000)
            gc.collect()
Just tested, it seems not fix my issue on M7. do you have an estimate of memory cost of openmv itself excluding framebuffer?
-Falong
Postby iabdalkader » Tue Jun 12, 2018 8:19 pm
Add a gc.collect at the end of detect_face_image:
        self.check_head_sideway(rotate_angle)
        gc.collect()
And gc.collect() before reading frames:
            gc.collect()
            del frames
            gc.collect()
            print("Free: %dKBs"%(gc.mem_free()/1024))
Unfortunately MicroPython's GC doesn't do very good defragmentation, reading bigger chunks if possible, will help.
Users browsing this forum: No registered users and 229 guests
