imagedata stream
shu higashiyama
imagedata stream
Postby shu higashiyama » Fri Oct 19, 2018 3:35 am
I asked about the directory of the previous image file.
But is my recognition incorrect and sending JPEG data via USB is wrong?
If my recognition is correct I was thinking that it can be checked on a serial monitor, but I can not confirm it.
Please tell me how you are sending camera data
Thank you
Re: imagedata stream
Postby kwagyeman » Fri Oct 19, 2018 12:06 pm
Hi, the camera sends a JPEG data stream over serial to the computer. You can use these scripts to see our protocol:
https://github.com/openmv/openmv/blob/m ... enmv_fb.py
https://github.com/openmv/openmv/blob/m ... yopenmv.py
If you need robust multi-platform code then you'd have to look at how our IDE does it which is much more battle hardened.
shu higashiyama
Postby shu higashiyama » Sat Oct 20, 2018 11:21 pm
Thank you for your quick response
I compiled pyopenmv.py
ImportError: no module named 'serial' occurs
Other errors also occur
I think that there are missing files or misconfiguration
Please point out.
Postby kwagyeman » Sun Oct 21, 2018 3:03 pm
sudo pip install pyserial
That's said, have you run python programs on a Linux device before? You may wish to reference some tutorial stuff. Using those scripts is for advanced users who know what they are doing.
shu higashiyama
Postby shu higashiyama » Sun Oct 21, 2018 11:32 pm
Thank you for your reply
I did it according to your advice
python test2.py
The compile error no longer occurred when I ran it.
Use version python 37-32 (windows 7ver.)
However, on Open MV IDE
Has occurred
Please tell me the setting of Open MV IDE
Thank you
Postby kwagyeman » Sun Oct 21, 2018 11:53 pm
Those script aren't runnable in OpenMV IDE. They are designed to be run on the linux computer by CPython.
shu higashiyama
Postby shu higashiyama » Wed Oct 24, 2018 2:30 am
Thank you for your support
As you gave me advice
Running two files on Ubuntu on Linux
I was able to display the camera image.
But serial data stream
I have not confirmed until
Please advice again.
Thank you
Postby kwagyeman » Thu Oct 25, 2018 4:40 pm
Hi, you can dump the serial data stream by using this code:
Just execute it in the loop:
https://github.com/openmv/openmv/blob/m ... mv.py#L179
See the 3 lines.
Users browsing this forum: No registered users and 279 guests
