Firmware updates
bogflap
Firmware updates
Postby bogflap » Wed Sep 26, 2018 9:43 am
When merges are made into the master branch at git/openmv are updated firmware files created anywhere.
The ones under the directory firmware have not changed in three months.
I am running under opensuse (linux) and am having difficulty cross compiling the sources.
I do not want to be a developer I just want to use the merged functionality e.g. Fir update (#382)
Re: Firmware updates
Postby kwagyeman » Thu Sep 27, 2018 2:23 am
Have fun. Example scripts are in the package. Just connect the camera to the I2C bus and run the scripts and it works.
firmware.zip
(914.71 KiB) Downloaded 59 times
bogflap
Postby bogflap » Thu Sep 27, 2018 9:03 am
Okay so I clone from git and run the bootloader on the bin files in the clone (I tried each bin file) in the OPENMV3 directory.
All I get is a bricked M7. The ide allows me to recover a bricked device. No problems.
Try to run AMG8833_camera.py and get AttributeError: 'module' object has no attribute 'FIR_AMG8833'
So where do I go from here
Postby kwagyeman » Thu Sep 27, 2018 12:44 pm
Hi, did you flash the firmware.bin file I posted above onto the camera? You don't have to do anything with git.
Maybe I gave you an old firmware. I can check again tonight.
bogflap
Postby bogflap » Thu Sep 27, 2018 1:49 pm
No I did not. Sorry I was not paying attention to your response. Will flash it shortly.
bogflap
Postby bogflap » Fri Sep 28, 2018 10:00 am
You got the right firmware, version 3.1.0.
Recognises the FIR_AMG8833 attribute.
Gives me a beautiful blue screen when running the AMG8833_camera.py script.
Ok so I need to connect a camera which will happen shortly
Postby iabdalkader » Fri Sep 28, 2018 1:42 pm
No firmware images are updated just before the release (with exceptions occasionally).
bogflap
Postby bogflap » Tue Oct 02, 2018 5:07 am
FYI.
The AMG8833 works just fine on the M7.
Took a while to try it as getting delivery of the AMG8833 was a little fraught.
Came from Mouser which is a delivery from across the pond.
bogflap
Postby bogflap » Tue Oct 16, 2018 10:12 am
FYI
The MLX90640 works just fine on the M7.
Sourced breakout board from pimoroni.
Postby kwagyeman » Tue Oct 16, 2018 10:15 am
Awesome!
