Saving the BAYER raw for sensor calibration
jl1982fm
Postby jl1982fm » Thu Jul 26, 2018 4:49 am
I want to save the Bayer unmodified image
Ideally i would like to save as a PGM file in which each pixel is each of the RGGB
import sensor, image, pyb
RED_LED_PIN = 1
BLUE_LED_PIN = 3
sensor.set_pixformat(sensor.BAYER) # or sensor.Bayer
sensor.set_framesize(sensor.VGA) # or sensor.QQVGA (or others)
pyb.LED(RED_LED_PIN).on()
sensor.skip_frames(time = 2000) # Give the user time to get ready.
pyb.LED(RED_LED_PIN).off()
pyb.LED(BLUE_LED_PIN).on()
sensor.snapshot().save("bayer.pgm") # or "example.bmp" (or others)
pyb.LED(BLUE_LED_PIN).off()
but when I do try to run the program I get this: OSError: Image is not PGM!
if I edit the modify the sensor.BAYER to sensor.GRAYSCALE I am able to save as pgm, but it is not the BAYER information as it has been filtered to grayscale.
Thanks before hand
Re: Saving the BAYER raw for sensor calibration
Postby kwagyeman » Thu Jul 26, 2018 11:49 am
Hi, we don't support saving bayer formats using the file system methods. Instead you have to write it out as a RAW binary file:
with open("file.bin", "wb") as f:
    f.write(img)
    f.close()
All images are treated as byte streams when passed to other micropython methods. So, the file object will just pull the image data as RAW bytes and save to the SD card.
jl1982fm
Postby jl1982fm » Thu Jul 26, 2018 5:50 pm
Dear Kwagyeman
Thanks a lot for the tip it worked, and now I am able to capture the images and do post processing for the calibration of the sensor that I need.
Kind regards
Postby iabdalkader » Sat Jul 28, 2018 11:57 pm
Actually we do now, you can save as ".raw" or leave the extension and the code will figure it out.
jl1982fm
Postby jl1982fm » Wed Aug 01, 2018 4:34 pm
Hi thanks,
I tried the raw option, but seem it didn't work. But I can work with the Raw
Anyway I am trying to adjust the exposure time and the gain. Which are the ranges of both parameters in the camera?
Also when I am setting the Exposure value to 3000000 microseconds I watch the camera LED blue light and is turn on less than 3 seconds, I have been playing a bit with the value but seems to be is like half of the microseconds. Is there a way i can print/save the exposure time of the camera?
And also regarding the next code, is there any other auto setting that I should put to false, or 0?
import pyb, machine, sensor, image, pyb, os, time
RED_LED_PIN = 1
BLUE_LED_PIN = 3
Exp=int('3000000')
estr=str(Exp)
gain=0.1
gstr=str(gain)
sensor.set_auto_gain(False, gain_db = 1.0)
sensor.set_framesize(sensor.VGA) # or sensor.VGA (or others)
sensor.skip_frames(time = 1000) # Let new settings take affect.
sensor.set_gainceiling(2)
sensor.set_contrast(0)
sensor.set_brightness(0)
sensor.set_saturation(0)
sensor.set_auto_exposure(False, exposure_us = Exp)
sensor.skip_frames(time = 1000) # Give the user time to get ready.
newName='OpenMV_r254g000b000_fullsize_gain'+gstr+'msec'+estr# Image file name based on RTC
def get_filename_datetime():
    # Use current date to get a text file name.
    return newName + ".bin"
# Get full path for writing.
name = get_filename_datetime()
path =  name
with open(path, "wb") as f:
    f.write(img)
    f.close()
Postby kwagyeman » Wed Aug 01, 2018 8:56 pm
Hi, you can get the exposure with the get_exposure() method...
https://github.com/openmv/openmv/blob/m ... 725.c#L443
https://github.com/openmv/openmv/blob/m ... 725.c#L405
Anyway, the exposure is limited by the chip's internal register scales. Exposure is 16-bits. So, you may be going above the max. That said, you can slow the sensor PLL down to effectively double the time scales:
Do:
reg = sensor.__read_reg(0xD)
sensor.__write_reg(0xD, (reg & 0x3F) | (0 << 6))
To turn the PLL off...
sensor.__write_reg(0xD, (reg & 0x3F) | (1 << 6))
And the above to cut the FPS by a bit and extend the exposure.
My C code queries the PLL registers so it will try to scale the exposure time you pass to actually be correct.
jl1982fm
Postby jl1982fm » Thu Aug 02, 2018 2:35 am
Hi thanks for the reply.
I need to work in the order of milliseconds, i was just testing in seconds with the LED so i could take the time with a chrono watch.
Now I am using the filename for storing the information of the gain and exposure using sensor.get_gain_db(), sensor.get_exposure_us(), while the sensor.get_exposure_us() works when I input 3000 the output is 2990 and when i input 10000 is 9988 (assuming is because 16 bit approx conversion)
example of the file name
OpenMV_r210g000b000_fullsize_gain17.78586msec9988.bin
Does not matter how I change the gain that I always have the same gain = 17.78586, does not matter if I change to 10, or 100 or 0.1. Do you know what could be wrong in my code?
RED_LED_PIN = 1
BLUE_LED_PIN = 3
Exp=int('10000')
estr=str(Exp)
gain=0.1
gstr=str(gain)
sensor.set_auto_gain(False, gain_db = gain)
sensor.set_gainceiling(128)
gainr=sensor.get_gain_db()
gainrs=str(gainr)
timexp=sensor.get_exposure_us()
timexp=str(timexp)
newName='OpenMV_r210g000b000_fullsize_gain'+gainrs+'msec'+timexp # Image file name based on RTC
path =  name
    f.write(img)
    f.close()
#pyb.LED(BLUE_LED_PIN).off()
jl1982fm
Postby jl1982fm » Thu Aug 02, 2018 9:25 am
But thanks a lot for your help I manage to sorted out, and looking forward to the Open MV H7. I searched in kickstarter but I didn't find it any link is welcomed.
Seems that was the line order, I put the line regarding the sensor gain later and now seems to work. So now I can control both Exposure and Gain without any problem. I hope all the autos are off with my code.
RED_LED_PIN = 1
BLUE_LED_PIN = 3
Exp=int('15000')
estr=str(Exp)
gain=10
gstr=str(gain)
gainrs=str(gainr)
timexp=str(timexp)
path =  name
    f.write(img)
    f.close()
Postby kwagyeman » Thu Aug 02, 2018 11:34 am
Hi, our Kickstarter website has not launched yet. ETA is next month. I'm working on media assets and the video right now.
Postby iabdalkader » Fri Aug 10, 2018 4:18 pm
Note the issue with saving BAYER using ".raw" or no extension has been fixed, and will be available in the next release.
Users browsing this forum: Bing [Bot] and 27 guests
