Help for haar cascade
Funky
Postby Funky » Sat Jul 21, 2018 10:33 am
* i use a translator
Hello, I am a beginner on openmv and I want to create a haar cascade
Can you tell me step by step instructions to follow
Best regards
Funky
Re: Help for haar cascade
Postby iabdalkader » Sat Jul 21, 2018 12:42 pm
1) Follow OpenCV tutorials to train a haar cascade:
https://docs.opencv.org/3.3.0/dc/d88/tu ... scade.html
https://github.com/mrnugget/opencv-haar ... r-training
https://coding-robin.de/2013/07/22/trai ... ifier.html
* Note you have to use -baseFormatSave to save the cascade in the old format
2) Convert xml to binary using the converter script:
python2 cascade_convert.py my_cascade.xml
3) Copy my_cascade.cascade to camera storage (flash or SD) and run the example script.
Funky
Postby Funky » Tue Jul 24, 2018 3:50 pm
Sorry for the late reply,
I tried your code but this line does not work. There is nothing in my samples folder
 perl bin/createsamples.pl positives.txt negatives.txt samples 1500\
   "opencv_createsamples -bgcolor 0 -bgthresh 0 -maxxangle 1.1\
   -maxyangle 1.1 maxzangle 0.5 -maxidev 40 -w 80 -h 40"
So i try with this code https://www.youtube.com/watch?v=Dg-4MoABv4I
it works with his photos.
Now i try with my pictures (ball) for positive img and i let the same negative img it not work
Have an idea why the camera does not detect them ?
Postby iabdalkader » Tue Jul 24, 2018 9:18 pm
If it's not detecting the object, try a higher threshold and/or lower scale.
