Any tracker implementation?
jiapei100
Contact:
Postby jiapei100 » Sat Jul 21, 2018 2:59 am
Hi, both:
I read multi_color_blob_tracking.py, which seems to track the detected blobs, but NOT.
I think the code just keeps detecting blobs for each frame, instead of tracking any of them.
A tracker is totally different from a detector...
By refering to https://www.learnopencv.com/object-trac ... pp-python/, you should be able to tell the difference between a tracker and a detector.
Anyway, any plan for trackers?
Cheers
Pei
Welcome to Longer Vision
http://www.longervision.ca
Re: Any tracker implementation?
Postby kwagyeman » Sat Jul 21, 2018 12:31 pm
We just have a detector. If you want to track then you should use the ROI method of find_blobs() to call a new find_blobs() task on each detected blob from an initial find_blobs().
If you'd like to see the functionality increase please help out and submit things we can incorporate into the releases. Me and Ibrahim are stretched thin on supporting new features.
