Controller Area Network
Hydrorion
Postby Hydrorion » Mon Jul 16, 2018 6:16 am
I'm trying to make a Controller Area Network connexion between a Microchip dsPIC33EV 5V and the OpenMV CAM M7. I already implement a transciever CAN "TJA1051" and i have CANoe to test the connection. Since the latest firmware version (3.0.0) i have a probleme, the commande "from pyb import CAN" send an error message : "importerror: cannot import name can" :
error can.PNG (33.83 KiB) Viewed 1120 times
i'm kind of confuse cause 5 days ago the same code worked fine
Anyone got the same probleme ?
Re: Controller Area Network
Postby iabdalkader » Mon Jul 16, 2018 8:39 am
Hi, unfortunately CAN was disabled in firmware 3.0 by mistake, I just fixed this, so it's going to be re-enabled in the next release. You can use any older firmware for now if you like or wait for the next release.
Hydrorion
Postby Hydrorion » Mon Jul 16, 2018 8:57 am
Okay thanks for the quick answer !
Hydrorion
Postby Hydrorion » Mon Sep 17, 2018 7:56 am
I just want to know when the next release will be up, it's been a while since the Controler Area Network is disable :/
Postby kwagyeman » Mon Sep 17, 2018 11:04 am
Ibrahim, can you post an updated firmware image?
Postby iabdalkader » Fri Sep 28, 2018 1:37 pm
Hi, the next release will be out in a day or two.
Users browsing this forum: Bing [Bot] and 50 guests
