General question about QtCreator
bogflap
Postby bogflap » Wed Jun 13, 2018 3:49 am
I use QtCreator to compile the IDE and I get the following under the general messages tab
[Inexact] Project MESSAGE: No gmock is found! To enable unit tests set GOOGLETEST_DIR
[Inexact] Project ERROR: No LLVM_INSTALL_DIR provided
Project MESSAGE: This project is using private headers and will therefore be tied to this specific Qt module build version.
Project MESSAGE: Running this project against other versions of the Qt modules may crash at any arbitrary point.
Project MESSAGE: This is not a bug, but a result of using Qt internals. You have been warned!
[Inexact] Project MESSAGE: This project is using private headers and will therefore be tied to this specific Qt module build version.
[Inexact] Project MESSAGE: Running this project against other versions of the Qt modules may crash at any arbitrary point.
[Inexact] Project MESSAGE: This is not a bug, but a result of using Qt internals. You have been warned!
QML module does not contain information about components contained in plugins.
Module path: /home/shaun/Qt/5.5/gcc_64/qml
See "Using QML Modules with Plugins" in the documentation.
Automatic type dump of QML module failed.
Errors:
"/home/shaun/Qt/5.5/gcc_64/bin/qmlplugindump" crashed.
Arguments: --builtins
This application failed to start because it could not find or load the Qt platform plugin "minimal"
in "".
Available platform plugins are: linuxfb, minimal, offscreen, xcb.
Reinstalling the application may fix this problem.
This is the only project where I get these messages. The project compiles okay without, as far as I can tell, any adverse effects.
Anybody any ideas about how I can prevent these messages or am I doing anything wrong.
Re: General question about QtCreator
Postby kwagyeman » Wed Jun 13, 2018 11:14 am
Hi, you can't get rid of those messages without messing with the qmake scanning process. They are all not serious errors so I just ignore them.
You can't ever get rid of these messages. Because they are generated by valid code being used in the QtCreator app.
I don't get these ones. But, they don't matter. None of that stuff above is used.
Errors:
in "".
QML is not used either. If you want to get rid of this you'd have to go disable more code from even being looked at (it's not compiled - but, if the scanner sees the code file you get issues).
