Using OpenMV camera with normal python 3 ?
devrup
Postby devrup » Fri May 25, 2018 1:26 am
I just got my OpenMV CAM M7 and played it for a while using IDE in Windows.
Specifically, HOW can I use openmv outside IDE ? Like through python3 scripts ?
THanks a lot.
Re: Using OpenMV camera with normal python 3 ?
Postby kwagyeman » Fri May 25, 2018 11:40 pm
We're a micropython board. So, all the tools here work:
https://github.com/micropython/micropyt ... pyboard.py
Postby iabdalkader » Tue May 29, 2018 8:52 pm
We also have our own OpenMV Python module here:
https://github.com/openmv/openmv/blob/m ... yopenmv.py
Using this you can communicate with the camera in "debug mode" (meaning you can read the framebuffer and the text buffer and run/stop scripts etc..).
Here's an example using pygame:
https://github.com/openmv/openmv/blob/m ... enmv_fb.py
OutoftheBOTS
Postby OutoftheBOTS » Wed May 30, 2018 4:13 am
I just followed your links and have a question.
In pyopenmv_fb.py the line of code what is script? Is it a file containing the python script??
pyopenmv.exec_script(script)
Postby kwagyeman » Thu May 31, 2018 12:59 am
Yes, this script allows you to send the OpenMV Cam a python script to run.
roger27
Postby roger27 » Sun Aug 18, 2019 7:28 pm
Do you guys have any examples how can i do this ? I mean how can used my openmv cam 7 with normal python?
Postby kwagyeman » Mon Aug 19, 2019 2:29 am
It doesn't support normal python because it's a microcontroller...
