Search part if a image
ten123
Postby ten123 » Mon May 21, 2018 2:33 pm
Hello :D ,
I recently got my OpenMV cam and wanted to make it run.
I started finding lines and realized how slow it is, so I would like to search only a part of a image, since I roughly know where it should be.
Thanks in advance.
Re: Search part if a image
Postby kwagyeman » Mon May 21, 2018 11:34 pm
Hi, find_line_segments is really slow yes, but, it uses the super accurate desktop code. Note that you wouldn't get better performance on a PI using OpenCV for find_line_segments, we use the same algorithm based on the LSD line segment detector.
That said, I previously had a faster line segment detector before I took out because a customer wanted it to be more stable. I will look to adding the faster version (it does like 20 FPS) back in soon.
Um, anyway, just pass the "roi=(x,y,w,h)" argument to the method to get faster compute.
ten123
Postby ten123 » Wed May 23, 2018 3:28 pm
Sorry for the late reply :D
Tried it and it works, thanks.
The amount of quality and support a peson gets with openMV is amazing.
