Distance calculation
SARAVANABAVAN
Postby SARAVANABAVAN » Mon May 21, 2018 5:43 am
Is there any possibility to calculate the distance of an object which was placed before the OpenMV CAM M7 in all the three X,Y,Z directions ?
ten123
Re: Distance calculation
Postby ten123 » Mon May 21, 2018 2:38 pm
I got it working in 2d , so I think that you probably can do it in 3d. I first calibrated the area(took measurment of the area at known distances x,y,z) and then used the angle between the camera and the object to calculate x,y,z.
Postby kwagyeman » Mon May 21, 2018 11:30 pm
If you use the AprilTags then you get the full 6 DOF pose of a tag - i.e. x/y/z translation and x/y/z orientation.
Otherwise, you need to measure things by hand and work out the geometry. The camera is not a distance sensor, but, you can calculate the distance an object must be from the camera given it's size.
Users browsing this forum: Bing [Bot] and 36 guests
