WiFi Shield Socket - No Bytes Read
thomas_newman
Postby thomas_newman » Fri May 11, 2018 12:15 pm
I am attempting to run the TCP Client sample that comes with the OpenMV IDE. I am able to successfully connect to my wifi network, but the socket returns 0 bytes on read. I have tested this with a few wifi networks. I have OpenMV V3 and ATWINC1500-MR210PB with the latest firmware.
Here is the code:
tcp_client_1.py
(812 Bytes) Downloaded 30 times
Re: WiFi Shield Socket - No Bytes Read
Postby kwagyeman » Sun May 13, 2018 3:10 pm
Hi, I've asked Ibrahim to take a look at this.
Postby iabdalkader » Mon May 14, 2018 8:54 pm
Hi, there was a bug in the recently updated sockets layer. I'm attaching a patched fw image if you want to use it now.
Note re that example script, the buffer size passed to recv should be large enough to hold the received data (otherwise it gets overwritten).
firmware.zip
(1.07 MiB) Downloaded 40 times
thomas_newman
Postby thomas_newman » Thu May 17, 2018 8:35 am
The updated firmware worked. Thank you for your help!
Users browsing this forum: No registered users and 275 guests
