Image importing
USER123rp
Image importing
Postby USER123rp » Tue May 08, 2018 4:19 am
IM new to Openmv IDE, Python in particular. Can someone help me??
My Image in located in desktop.
template = image.Image('C:\Users\****\Desktop\rr.jpg')
(NOTE I replaced my name with ****)
ERROR: invalid syntax
Thanks.
Re: Image importing
Postby kwagyeman » Wed May 09, 2018 1:14 am
Hi, please try to load an RGB565 BMP file, or in better yet, PNM or PPM files.
USER123rp
Re: Image importing
Postby USER123rp » Wed May 09, 2018 2:29 am
Still same thing after converting image, but if I remove "C:\" from path error says "Could not find path".
Could you send a full example of the image path??
Thanks!
Re: Image importing
Postby kwagyeman » Wed May 09, 2018 2:48 am
The image has to be on the camera.
I.e. please put the image on the SD card that is inserted into the camera. The image path is then "/folder/file.extension"
USER123rp
Re: Image importing
Postby USER123rp » Wed May 09, 2018 4:56 am
Thanks for the help!!
