Trouble with PIN 8
166inter
Trouble with PIN 8
Postby 166inter » Fri May 04, 2018 9:05 pm
Hello, I have an MVR rover (diyrobocars.com/2017/10/01/a-minimum-viable-racer-for-openmv/) and it seems like the servo motors are going on and off. I think I have it narrowed down to pin 8. If I connect pin 7 to power either motor, they run fine. But when using pin 8, the motors lag or sometimes run if they are on a certain angle. I have tried using a different wire but that did not help. Any idea as to what the problem might be?
Also I tried to use pin 9 and changing the code for that, but did not get any response from the motor.
I don't have very much experience with this kind of stuff..
Thanks!
Re: Trouble with PIN 8
Postby iabdalkader » Sat May 05, 2018 3:50 pm
Hi, maybe pin 8 and 9 are shorted, can you test with a meter ? Also please post your code.
166inter
Postby 166inter » Sun May 06, 2018 9:38 pm
I do not own a meter but I will see if I can get my hands on one this week! Here is the code:
# Color Line Following Example with PID Steering
# For this script to work properly you should point the camera at a line at a
# 45 or so degree angle. Please make sure that only the line is within the
# camera's field of view.
import sensor, image, pyb, math, time
from pyb import LED
from pyb import Pin, Timer
tim = Timer(4, freq=1000) # Frequency in Hz
cruise_speed = 60  # how fast should the car drive, range from 0 to 100
steering_direction = -1   # use this to revers the steering if your car goes in the wrong direction
steering_gain = 1.7  # calibration for your car's steering sensitivity
steering_center = 60  # set to your car servo's center point
kp = 0.8   # P term of the PID
ki = 0.0     # I term of the PID
kd = 0.4    # D term of the PID
# The below thresholds track in general red/green things. You may wish to tune them...
# old thresholds = [(30, 100, 15, 127, 15, 127), # generic_red_thresholds
#              (30, 100, -64, -8, -32, 32), # generic_green_thresholds
#              (0, 15, 0, 40, -80, -20)] # generic_blue_thresholds
threshold_index = 2
# 0 for red, 1 for green, 2 for blue
thresholds = [(0, 100, -1, 127, -25, 127), # generic_red_thresholds
              (0, 100, -87, 18, -128, 33), # generic_green_thresholds
              (0, 100, -128, -10, -128, 51)] # generic_blue_thresholds
# You may pass up to 16 thresholds above. However, it's not really possible to segment any
# scene with 16 thresholds before color thresholds start to overlap heavily.
# Each roi is (x, y, w, h). The line detection algorithm will try to find the
# centroid of the largest blob in each roi. The x position of the centroids
# will then be averaged with different weights where the most weight is assigned
# to the roi near the bottom of the image and less to the next roi and so on.
ROIS = [ # [ROI, weight]
        (38,1,90,38, 0.4),
        (35,40,109,43,0.2),
        (0,79,160,41,0.6)
blue_led  = LED(3)
old_error = 0
measured_angle = 0
set_angle = 90 # this is the desired steering angle (straight ahead)
p_term = 0
i_term = 0
d_term = 0
old_time = pyb.millis()
radians_degrees = 57.3 # constant to convert from radians to degrees
def constrain(value, min, max):
    if value < min :
        return min
    if value > max :
        return max
        return value
ch1 = tim.channel(1, Timer.PWM, pin=Pin("P7"), pulse_width_percent=0)
ch2 = tim.channel(2, Timer.PWM, pin=Pin("P8"), pulse_width_percent=0)
def steer(angle):
    global steering_gain, cruise_speed, steering_center
    angle = int(round((angle+steering_center)*steering_gain))
    angle = constrain(angle, 0, 180)
    angle = 90 - angle
    angle = radians_degrees * math.tan(angle/radians_degrees) # take the tangent to create a non-linear response curver
    left = (90 - angle) * (cruise_speed/100)
    left = constrain (left, 0, 100)
    right = (90 + angle) * (cruise_speed/100)
    right = constrain (right, 0, 100)
    print ("left: ", left)
    print ("right: ", right)
    # Generate a 1KHz square wave on TIM4 with each channel
    ch1.pulse_width_percent(left)
    ch2.pulse_width_percent(right)
def update_pid():
    global old_time, old_error, measured_angle, set_angle
    global p_term, i_term, d_term
    now = pyb.millis()
    dt = now - old_time
    error = set_angle - measured_angle
    de = error - old_error
    p_term = kp * error
    i_term += ki * error
    i_term = constrain(i_term, 0, 100)
    d_term = (de / dt) * kd
    old_error = error
    output = steering_direction * (p_term + i_term + d_term)
    output = constrain(output, -50, 50)
    return output
# Compute the weight divisor (we're computing this so you don't have to make weights add to 1).
weight_sum = 0
for r in ROIS: weight_sum += r[4] # r[4] is the roi weight.
# Camera setup...
sensor.__write_reg(0x6B, 0x22)  # switches camera into advanced calibration mode. See this for more: http://forums.openmv.io/viewtopic.php?p=1358#p1358
sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed.
sensor.set_vflip(True)
sensor.set_hmirror(True)
sensor.set_auto_gain(True)    # do some calibration at the start
sensor.set_auto_whitebal(True)
sensor.skip_frames(time = 4000)  # When you're inside, set time to 2000 to do a white balance calibration. Outside, this can be 0
sensor.set_auto_gain(False)   # now turn off autocalibration before we start color tracking
    img = sensor.snapshot().histeq() # Take a picture and return the image. The "histeq()" function does a histogram equalization to compensate for lighting changes
    print("FPS: ",clock.fps())
    centroid_sum = 0
    for r in ROIS:
        blobs = img.find_blobs([thresholds[threshold_index]], roi=r[0:4], merge=True) # r[0:4] is roi tuple.
        if blobs:
            # Find the index of the blob with the most pixels.
            most_pixels = 0
            largest_blob = 0
            for i in range(len(blobs)):
                if blobs[i].pixels() > most_pixels:
                    most_pixels = blobs[i].pixels()
                    largest_blob = i
            # Draw a rect around the blob.
            img.draw_rectangle(blobs[largest_blob].rect())
            img.draw_cross(blobs[largest_blob].cx(),
                           blobs[largest_blob].cy())
            centroid_sum += blobs[largest_blob].cx() * r[4] # r[4] is the roi weight.
    center_pos = (centroid_sum / weight_sum) # Determine center of line.
    # Convert the center_pos to a deflection angle. We're using a non-linear
    # operation so that the response gets stronger the farther off the line we
    # are. Non-linear operations are good to use on the output of algorithms
    # like this to cause a response "trigger".
    deflection_angle = 0
    # The 80 is from half the X res, the 60 is from half the Y res. The
    # equation below is just computing the angle of a triangle where the
    # opposite side of the triangle is the deviation of the center position
    # from the center and the adjacent side is half the Y res. This limits
    # the angle output to around -45 to 45. (It's not quite -45 and 45).
    deflection_angle = -math.atan((center_pos-80)/60)
    # Convert angle in radians to degrees.
    deflection_angle = math.degrees(deflection_angle)
    # Now you have an angle telling you how much to turn the robot by which
    # incorporates the part of the line nearest to the robot and parts of
    # the line farther away from the robot for a better prediction.
#    print("Turn Angle: %f" % deflection_angle)
    now = pyb.millis()
    if  now > old_time + 0.02 :  # time has passed since last measurement; do the PID at 50hz
        blue_led.on()
        measured_angle = deflection_angle + 90
        steer_angle = update_pid()
        old_time = now
        steer (steer_angle)
#        print(str(measured_angle) + ', ' + str(set_angle) + ', ' + str(steer_angle))
        blue_led.off()
Postby kwagyeman » Sun May 06, 2018 10:17 pm
Can you narrow it down to where you think the error is?
166inter
Postby 166inter » Thu May 10, 2018 11:17 am
I think the error really had to do with the thresholds! I used this code to test the motors with each pin (without doing doing any computer vision):
# Untitled - By: Nikolas - Fri May 4 2018
from pyb import LED
    ch1.pulse_width_percent(90)
    ch2.pulse_width_percent(90)
^^And with this code the motors were running fine through each pin.
I went into the threshold editor and changed the thresholds (I had done this before, but I possibly did not save it)
Thank you :)
Users browsing this forum: Raul_ and 5 guests
