draw_rectangle color mistake
kidswong999
Postby kidswong999 » Wed Apr 11, 2018 4:50 am
Hello, in the IDE, the border of the draw_rectangle function is not quite right.
Firmware Version: 2.7.0
IDE Version: 1.8.1
import sensor, image, time
sensor.skip_frames(time=2000)
    img=sensor.snapshot()
    img.draw_rectangle((50,50,100,100),color=(255,0,0))
Re: draw_rectangle color mistake
Postby iabdalkader » Wed Apr 11, 2018 12:02 pm
Hi, it's not a bug, it's just the heavy JPEG compression. Try this:
img.draw_rectangle((50,50,100,100),color=(255,0,0), thickness=2)
Postby kwagyeman » Wed Apr 11, 2018 12:31 pm
Thicknesses is only available in the new firmware. I'll upload a copy.
Postby kwagyeman » Thu Apr 12, 2018 3:43 am
Latest firmware is attached. WiFi is broken, but, will fix before the release which is coming soon.
openmv.zip
(2.14 MiB) Downloaded 18 times
