Running main.py on boot (external power supply)
gregjeffrey
Postby gregjeffrey » Thu Apr 05, 2018 3:27 pm
I'm trying to auto-run the main.py script on startup, and it works fine when plugging in the OpenMV cam to a USB port on my pc. However, when I try to turn on the board with an external power supply it doesn't appear to be running the code. Is there a difference in how the board boots up given USB power vs an external power supply?
Greg
Re: Running main.py on boot (external power supply)
Postby kwagyeman » Thu Apr 05, 2018 5:18 pm
No, there's no difference. Can you verify your script was saved to the camera correctly? You should see your script as mian.py on the camera's file system.
gregjeffrey
Postby gregjeffrey » Thu Apr 05, 2018 7:30 pm
We solved the problem - it had to due with a hidden ._main.py file being saved on the board when someone tried to delete an old main.
Greg
