Can I connector another image sensor to SPI?
lab
Postby lab » Wed Mar 21, 2018 9:08 pm
I want to connect a 10MP camera through SPI in the OpenMV booard? Can I perform machine vision and Wifi?
Also do you have plans to make a board with higher mega pixel camera?
Re: Can I connector another image sensor to SPI?
Postby kwagyeman » Thu Mar 22, 2018 1:19 am
Hi, we don't have RAM on board to buffer a 10M image. You couldn't do machine vision on that anyway. Real-time algorithms tend to run at low resolutions to achieve a high FPS.
As for a higher res camera, no, we're going to be moving to a global shutter camera though which is what a lot of folks want along with thermal vision.
lab
Postby lab » Thu Mar 22, 2018 1:24 am
Thanks for the response. I understand realtime requirement for MV.
Can we connect a second high resolution camera in the board through SPI and use it for only still images to μSD Card?
Postby kwagyeman » Thu Mar 22, 2018 1:41 am
Um, I suppose. The processor is quite capable. The SPI bus does 45-54 Mb/s.
You needn't use an OpenMV Cam though if you're not using it's main camera.
