Standalone motion coordinates detector
I just acquired the OpenVM cam so i’m discovering the product.
I need it to act as standalone motion sensor able to send XY coordinates to a patching application on Windows called vvvv https://vvvv.org/.
I read on the forum that a way might be using UART or USB.
Is it possible?
Regards.
Ben
Yes, you’d use the USB VCP port class to do this. On the PC then the camera is just a serial port you open and read text from. Data will move at 12 Mb/s.
Note however, using this feature is not possible while debugging with OpenMV IDE.
So, alternatively, you can use one of he hardware serial ports on the OpenMV Cam and a serial to USB adapter to develop your app and then switch to the USB VCP port once you have all the bugs out.
