clock.fps() returning 0
I have an application that prints clock.fps() to UART. Usually the value hovers around 92 FPS which is great but once in a while, there is a sudden drop to 0 after which the value bounces back up.
Is this happening because of the garbage collector? I have tried declaring most variables as const or declaring them outside the main while loop. Are there any solutions other than calling gc.disable() ?
Hi, can I see your code?
Here’s the implementation of the code BTW: https://github.com/openmv/openmv/blob/master/src/omv/py/py_time.c#L28
It’s super easy to roll your own version of it.
I see. However, systick can wrap around right?
I could email you my code.
Yeah, it can.
I suggest just using pyb.millis() and make your own FPS counter.
