Find_Line_Seg doesn't work with ROI from saved image?
s1000rr
Postby s1000rr » Wed Feb 07, 2018 7:58 pm
I've noticed a weird problem that has to be related to my code implementation. When I try to run find_line_segments() or find_lines() from a saved image, I get a list of lines that makes sense. When I try to run find_line_segments(roi = (...)) or find_lines(roi = (...)) on the same image, I don't receive any lines back. I've attached two images showing my IDE with both cases. Any ideas?
With ROI:
Without ROI:
Re: Find_Line_Seg doesn't work with ROI from saved image?
Postby kwagyeman » Wed Feb 07, 2018 10:31 pm
Which algorithm is this? The old one? This looks like a bug. Check that you are passing ROI right.
s1000rr
Postby s1000rr » Thu Feb 08, 2018 12:14 pm
This is the old find_line_segment, I'm running firmware v2.5.
However, this same problem occurs for find_lines as well, has this algorithm been updated as well?
What do you mean by check if I'm passing ROI right?
s1000rr
Postby s1000rr » Thu Feb 08, 2018 2:40 pm
I just ran it in that latest firmware and it finds the line segments using the roi option. Looks like a bug in the old version of find_lines.
