AttributeError: 'module' object has no attribute 'alloc_extra_fb'
sig_UVa78
Postby sig_UVa78 » Wed Jan 24, 2018 9:10 pm
I received the error in the subject link when I ran the 20-Frame-Differencing example openmv/usr/examples/20-Frame-Differenci ... rencing.py. The program halts at line 24.
Anything I can do to fix this? I couldn't find the error on the forums.
Thanks for your help. Cool product so far, but I am a noob, so I'm stumbling through.
Re: AttributeError: 'module' object has no attribute 'alloc_extra_fb'
Postby kwagyeman » Wed Jan 24, 2018 9:25 pm
You need to install the latest firmware which was just released. It's not packaged for download yet though. See the release tab on the OpenMV GitHub.
sig_UVa78
Postby sig_UVa78 » Wed Jan 24, 2018 9:52 pm
Thank you. I am not sure what you mean by Release tab though.
I found this folder: https://github.com/openmv/openmv/tree/master/firmware
Would I still be able to use the IDE to update the firmware or can it only be done manually?
OPENMV4 folder?
Thanks!
Postby kwagyeman » Wed Jan 24, 2018 10:11 pm
https://github.com/openmv/openmv/releases
Use either the firmware.bin or OpenMV.dfu file in the OPENMV3 folder. You can use the IDE to update the camera.
sig_UVa78
Postby sig_UVa78 » Thu Jan 25, 2018 9:30 pm
So I downloaded those files. However in the IDE, I can't seem to force it to ask for the DFU.
I read in the hardware setup tutorial that it would prompt me to do so, but my firmware is also up-to-date with 2.6.0 (according the IDE). It does ask me if I want to reset to the release version, but that didn't seem to go well. I'm still at 2.6.0.
Thanks for your patience!
Postby kwagyeman » Fri Jan 26, 2018 12:47 am
See Tools->Run bootloader.
sig_UVa78
Postby sig_UVa78 » Fri Jan 26, 2018 9:17 pm
That worked. Thank you!
Nando
Postby Nando » Mon Feb 12, 2018 12:03 pm
Hi kwagyeman,
I've run across the same 'alloc_extra_fb' problem trying to use one of the examples on your github, https://github.com/kwagyeman/openmv/blo ... calflow.py
Is the OPENMV3 folder for the OpenMV M7 cam?
I was looking at the old firmwares, and for example firmware 2.0 has a clear "OPENMV7" folder.
Postby kwagyeman » Mon Feb 12, 2018 12:30 pm
OpenMV 3 is the OpenMV Cam M7. OpenMV 2 is the M4 board, 1 is the oldest OpenMV Cam from 2013 that was never sold commerically. 4 is the upcoming H7 model.
Nando
Postby Nando » Mon Feb 12, 2018 1:18 pm
Thank you very much.
The update and python code on the openmv worked right away. Now to get the whole thing working.
