CAN CUMMUNICATION OSERROR:16
Posted: Mon Jan 08, 2018 7:38 am
by adrianhergi
Hello, I am trying to communicate via CAN but I am always gettitn an OsError_16 after trying to send three messages. However in the bus I dont see those messages.
Here is my code:
# Untitled - By: Juan - lu. ene. 8 2018
import sensor, image, time, utime
import pyb
can = pyb.CAN(2)                        #The bus 2(PB12, PB13) is the only can bus on the Open MVCam
can.init(pyb.CAN.NORMAL, extframe=False, prescaler=18, sjw=1, bs1=8, bs2=3) #250kb/s
# APB1 = 54MHz, Prescaler 18 et 250kB/s --> 12 time quanta par bit (1 + 8 + 3 = 12)
can.setfilter(0, pyb.CAN.LIST16, 0, [0x700, 0x700, 0x701, 0x702], rtr = [0, 1, 0, 0])
tiempo= utime.ticks_ms() # get millisecond counter
aux=pyb.freq();
print(aux)
    data= b'\x01\x50'
    tiempo2=utime.ticks_ms()
    if (tiempo + 1000)< (tiempo2):
        can.send(data, id = 0x702, timeout=0, rtr=False)
        print("can : message sent") # [Debug]
And the Serial Output
>>> (216000000, 216000000, 54000000, 108000000)
can : message sent
can : message sent
can : message sent
  File "<stdin>", line 28, in <module>
OSError: 16
MicroPython v1.9.2-4416-g17df8ae1 on 2017-11-04; OPENMV3 with STM32F765
Any ideas?
Re: CAN CUMMUNICATION OSERROR:16
Posted: Mon Jan 08, 2018 10:39 pm
Hi, I've never done anything with the CAN peripheral. Ibrahim might know how to work it. Pinging him.
Note, if you ask for help on the main MP forums they might know more.
Posted: Tue Jan 09, 2018 2:54 pm
by iabdalkader
I'm not sure either, I don't have the hardware to test CAN. OSError 16 is "Device or resource busy" I found this on MP forums:
https://forum.micropython.org/viewtopic.php?t=1923
