Eye detection + drawing
aakoch
Postby aakoch » Wed Dec 06, 2017 11:17 pm
I'm trying to use the face_eye_detection.py script but for some reason drawing within the second for loop doesn't work. I've tried commenting out the img.draw_rectangle(face) thinking maybe it couldn't draw more than once on an image, but still no luck. Has anyone else had this issue? What am I doing wrong?
Thanks.
Re: Eye detection + drawing
Postby kwagyeman » Thu Dec 07, 2017 12:43 am
The haar cascade eye detector is just generally not that good. The face detector is pretty good but the eye detector one doesn't work that well. In the future we may improve that feature but we've been swamped with other things folks want us to build out.
aakoch
Postby aakoch » Sun Dec 10, 2017 8:14 pm
It isn't the detection of the eyes that is the issue. Although it isn't great, it works. The issue is with drawing.
Postby kwagyeman » Sun Dec 10, 2017 9:46 pm
Which script are you running? This one?
# Face Eye Detection Example
# This script uses the built-in frontalface detector to find a face and then
# the eyes within the face. If you want to determine the eye gaze please see the
# iris_detection script for an example on how to do that.
import sensor, time, image
# Reset sensor
# Sensor settings
sensor.set_contrast(1)
sensor.set_gainceiling(16)
# Load Haar Cascade
# By default this will use all stages, lower satges is faster but less accurate.
eyes_cascade = image.HaarCascade("eye", stages=24)
print(face_cascade, eyes_cascade)
# FPS clock
while (True):
    # Capture snapshot
    # Find a face !
    objects = img.find_features(face_cascade, threshold=0.5, scale_factor=1.5)
    # Draw faces
    for face in objects:
        # Now find eyes within each face.
        # Note: Use a higher threshold here (more detections) and lower scale (to find small objects)
        eyes = img.find_features(eyes_cascade, threshold=0.5, scale_factor=1.2, roi=face)
        for e in eyes:
            img.draw_rectangle(e)
    # Print FPS.
    # Note: Actual FPS is higher, streaming the FB makes it slower.
It doesn't draw a rectangle in this if it doesn't detect the eyes... which happens easily.
aakoch
Postby aakoch » Sun Dec 10, 2017 10:39 pm
I took that script and modified it to 1) light up the red LED, 2) use a circle for the face (to differentiate it from the eyes) and 3) quit:
from pyb import LED
red_led   = LED(1)
# Reset sensor
# Sensor settings
sensor.skip_frames()
# Load Haar Cascade
face_cascade = image.HaarCascade("frontalface", stages=30)
# FPS clock
def circle_from_rect(rect):
    x = round(rect[2] / 2) + rect[0]
    y = round(rect[3] / 2) + rect[1]
    r = round(rect[3] / 2)
    return (x, y, r)
notFound = True
while (notFound):
    # Capture snapshot
    # Find a face !
    objects = img.find_features(face_cascade, threshold=0.5, scale_factor=1.4)
    # Draw faces
        print(face)
        #img.draw_rectangle(face)
        (x,y, r) = circle_from_rect(face)
        img.draw_circle(x, y, r)
        for e in eyes:
            print("found eyes")
            print(e)
            #(x, y, r) = circle_from_rect(e)
            #img.draw_circle(x, y, r)
            red_led.on()
            time.sleep(5000)
            notFound = False
    # Print FPS.
    #print(clock.fps())
It shows the last frame, always with a circle around my face even though it detected my eyes.
This isn't a big deal since I don't plan on using it long-term. I just was wondering if anyone else had this issue and they knew why.
Adam
Postby kwagyeman » Sun Dec 10, 2017 10:52 pm
Oh, it's because you do the sleep(5000). The image is only flushed to the IDE on img.sensor_snapshot(). If you want to force an image flush without snapshot() do:
http://docs.openmv.io/library/omv.senso ... nsor.flush
Before the sleep call.
aakoch
Postby aakoch » Mon Dec 11, 2017 9:03 pm
Thanks!
