Gonzague
Postby Gonzague » Thu Oct 05, 2017 8:57 am
I am trying to implement a wathdog on my OpenMV Cam M7.
As explained to that link : http://docs.openmv.io/library/machine.WDT.html
I wrote that code :
watchdog = machine.WDT(timeout=1000)
watchdog.feed()
But when I run the script I get this error :
AttributeError: 'module' object has no attribute 'WDT'
Do somebody know how to use correctly the watchdog timer ?
Re: Watchdog
Postby kwagyeman » Thu Oct 05, 2017 11:11 am
Mmm, it might be disabled in our code. Can you summit a bug to the GitHub repo about this. It will get fixed then for the next firmware release.
Re: Watchdog
Postby iabdalkader » Thu Oct 05, 2017 7:49 pm
This code is enabled in the current development firmware. If you don't want to wait for the next release, you can clone the repo and upload the firmware image.
Gonzague
Re: Watchdog
Postby Gonzague » Fri Oct 06, 2017 8:54 am
I upgraded the firmware from the repo and now it works properly.
Thanks for your help !
Users browsing this forum: Bing [Bot] and 197 guests
