findContours
procrock
findContours
Postby procrock » Tue Feb 09, 2016 10:59 am
I'm the proud owner of an OpenMV Cam and it works great right out of the box!
I noticed that the MicroPython which it comes with has things like dilate, erode and threshold, but does not have some of the more advanced OpenCV functions like findContours and background subtraction. What are my options for getting those functions? Wait for a port? If so, what is the timeline? Can I port it myself and recompile everything (be honest if this will be next to impossible)?
Sean
Re: findContours
Postby kwagyeman » Tue Feb 09, 2016 1:15 pm
Actually, I'm working on adding those, Um, if you clone the main repo you can get a lot of fixes. I'll be merging in with my updates to add a bunch of features soon. I just have to test them.
As for doing your own development. Its... actually very easy. I'll post an update tonight with all the instructions for this. For now, follow this here: https://github.com/openmv/openmv/wiki.
Getting code building and flashing the camera is a snap. You're going to be waiting a while for findContours, but, we'll be working on background subtraction next week.
Once I merge my updates with the main branch feel free to dive into the code and add the findContours function if you want. That's what's great about this project. You can merge your update back into the main branch.
If you need help for understanding the code, just post here. It's actually not that complex. Took me about a day to get an idea of what was what.
procrock
Re: findContours
Postby procrock » Tue Feb 09, 2016 1:25 pm
Hi kwagyeman,
Thanks very much for your quick response. I'm very impressed with this project.
Sean
Tree
Re: findContours
Postby Tree » Thu Sep 01, 2016 9:07 pm
I was wondering if there is any update on findContours ?
Thank you.
Re: findContours
Postby kwagyeman » Thu Sep 01, 2016 11:43 pm
Hi, we haven't been working on any computer vision functionality right now. We've been focused on the tool set. Note that we have background subtraction now.
Tree
Re: findContours
Postby Tree » Fri Sep 02, 2016 1:48 pm
If you could point me in the right direction to begin incorporating this function into openmv I would like to help.
I am just beginning to familiarize myself with your code.
Re: findContours
Postby iabdalkader » Fri Sep 02, 2016 3:17 pm
Tree wrote:If you could point me in the right direction to begin incorporating this function into openmv I would like to help.
Hi, I would start by implementing the algorithm in omv/img/contours.c/
* Add functions prototypes to imlib.h, the source file to src/omv/Makefile (after eye.c) and the object file to src/Makefile (after eye.o)
Add MP bindings to omv/py/py_image.c (see how other functions are implemented, for examples, search for find_blobs, basically you need a C function, an MP_DEFINE_CONST_FUN_OBJ_* and finally an entry in locals_dict_table).
You'll need to add qstrings (to use them in your function and the dict_table, say MP_QSTR_find_contours) those live in omv/py/qstrdefsomv.h
Make sure to do make clean first after adding qstrs.
Other notes:
* If you need to alloc fast memory use fb_alloc/free this allocates memory in the unused framebuffer area, make sure to free it (it's a stack like allocation).
* See imlib.h for util functions.
Re: findContours
Postby iabdalkader » Fri Sep 09, 2016 12:19 pm
Hey
Following on my notes in the last post, here's a commit that shows how to add a function to the image library:
https://github.com/openmv/openmv/commit ... 2afa357c64
Note you could add your code there for testing, send a PR and I'll merge it. Later I could help with moving the code to a separate C file.
Tree
Re: findContours
Postby Tree » Wed Sep 14, 2016 8:01 pm
Thank you for the direction in getting started. I will take a look at that commit.
Hopefully I have enough code progress and time to test in the next few days.
procrock
Re: findContours
Postby procrock » Mon May 01, 2017 11:11 pm
Hi, I've looked around and can't see background subtraction as a method. Is there something else I should be looking under?
Sean
Re: findContours
Postby kwagyeman » Mon May 01, 2017 11:37 pm
The method is here:
http://docs.openmv.io/library/omv.image ... difference
Please see the frame differencing script under the filters examples.
procrock
Re: findContours
Postby procrock » Tue May 02, 2017 12:37 am
my apologies. I should have seen that. Thanks!
mjs513
Re: findContours
Postby mjs513 » Wed May 03, 2017 10:46 am
Was wondering what the status was on findcontours?
Re: findContours
Postby kwagyeman » Wed May 03, 2017 11:48 am
Um, wow, this is an old thread.
Find contours will not be implemented. We have find_blobs() instead. It basically does everything you'd normally use contour finding to do: http://docs.openmv.io/library/omv.image ... find_blobs -> and here's the blob object: http://docs.openmv.io/library/omv.image ... lob-object
Note that I could make find countours pretty easily as find blobs has the pixel positions of the edges of a blob when its walking through the blob. However, the list of pixels is really big and you'd run out of RAM on an MCU. OpenCV can use that function because it expects you to have several mega bytes of RAM to save all pixel locations of the edge of a blob.
mjs513
Re: findContours
Postby mjs513 » Wed May 03, 2017 6:50 pm
:) Well, I just got my cam and getting into things slowly. I will check out the blobs. Thanks for the info. By the way couldn't you write to the data to the sd card then do the analysis in chunks. Know it would be slow but better than nothing. Just thinking out loud. Used to have to do this in the old days since RAM (yes RAM was almost non-existent).
Mike
Re: findContours
Postby kwagyeman » Wed May 03, 2017 8:34 pm
The main point of the OpenMV Cam is for use in simple robotic apps. The "goal" is to make things easy for folks to do cool stuff. The OpenCV way of doing things gives you more flexibility but at a cost of a lot more complexity.
Note that I do actually use the file system actively for things like frame differencing. In that case I actually can difference a frame on disk with one in RAM. This involves loading chunks of the image at a time and working on them.
jiapei100
Contact:
Re: findContours
Postby jiapei100 » Sun Jun 17, 2018 7:05 am
Is there a corresponding function to OpenCV's findContours already ?
Cheers
Pei
Welcome to Longer Vision
http://www.longervision.ca
Re: findContours
Postby kwagyeman » Sun Jun 17, 2018 11:29 am
I have no plans to add that feature, you are free to add port the c code for it to the platform if you like. We offer find blobs which finds color blobs. As for finding contours around a object using a CNN outperforms traditional countur algorithms so we have no plans to support find_contours() for gesture recong. Ibrahim found a data set for this and was working on training a CNN to do it.
jiapei100
Contact:
Re: findContours
Postby jiapei100 » Sun Jun 17, 2018 3:52 pm
Great !! How can I get involved ?? We really need this function....
Where can I download the dataset????
Pei
Re: findContours
Postby kwagyeman » Mon Jun 18, 2018 1:47 pm
Basic getting started is here: https://github.com/openmv/openmv/tree/master/ml/cmsisnn
We'll be rolling all the docs out soon. I'm just moving from Oakland to SF so I'm quite busy with other things. In the mean time focus on training some nets on the PC. 3 layer nets like (Conv -> Pool -> ReLu ) * 3 -> IP are good.
http://www.idiap.ch/resource/gestures/
Google for data sets.
I know this is all poorly documented now but moving forwards we'll be putting our effort into training nets for data sets. Me and Ibrahim are both buying serious training rigs to train up lots of nets.
jiapei100
Contact:
Re: findContours
Postby jiapei100 » Mon Jun 18, 2018 4:22 pm
1. caffe instead of caffe2?
2. python2 instead of python3?
Anyway, catching up...
Re: findContours
Postby kwagyeman » Mon Jun 18, 2018 5:49 pm
We're basically using what ARM provided us. The implement work was mostly done by them. We're just taking it from demo quality to usable.
Clemz
Contact:
Re: findContours
Postby Clemz » Sat Feb 16, 2019 10:14 am
Hi all , I've pre-ordered the H7 coming camera , and I'm really newby with OpenMV cams.. waiting for the cam I'm checking the examples in the IDE software I already installed some days ago .
So I ordered this cam to make a basic Background subtraction work , but on 'no-color' objects ( small black objects moving ) . I've checked on the forum and I 'm not sure that the find blob method works on black objects ? did I missunderstood and will this work ? (it looks like it seems to look for a color range threshold no ? )
currently I'm using a working Rpi+ picam V2 solution, using OpenCV ( using background subtraction MOG2 type then FindContours method then 'minEnclosingCircle' method which gives me something like in the attached image . ) this allows me to find the biggest moving object ( white 'blob' ) and gives me his coordinates x,y + the Circle radius (which allows me to find an approximate detph as I know the average blob real world size .. so = 'z' coordinate).
Do you think we can get such workflow/result with OpenMV H7 cam ?
Thanks by advance for any input over this :) .
and keep rocking guys , your product looks awesome , can't wait to receive it .
Clem
Re: findContours
Postby kwagyeman » Sat Feb 16, 2019 4:13 pm
Hi, I added all the features find_countours provides in OpenCV to our API. We have a minimum circle method now. If you'd like to the un-released firmware let me know.
As for doing what you want. First use frame differencing to create a difference image and then just threshold that image for non-block things (i.e. differences). find_blobs() will then give you the objects and you can filter in python to find the largest ones.
Clemz
Contact:
Re: findContours
Postby Clemz » Sat Feb 16, 2019 6:17 pm
Hi Nyamekye ,
:) thanks for those great additions ! Do you have examples scripts of those already maybe ?
So this new minimumCircle method will return a radius value too ? ( to use for guessing the 'Z detph' )
yes please if you can share with me/us this new version that'll be great :)
Ha ok for the frame differencing , I'll check this more in details .
Thanks by advance
Clément
Re: findContours
Postby kwagyeman » Sat Feb 16, 2019 7:28 pm
Example:
        if blob.elongation() > 0.5:
            img.draw_line(blob.major_axis_line(), color=(0,255,0))
            img.draw_line(blob.minor_axis_line(), color=(0,0,255))
Do img.draw_circle(blob.enclosing_circle()) to draw the circle that encloses the blob. Note that the enclosing circle depends on the blob having a unique'ish shape. Otherwise the min area rect won't be stable.
firmware.zip
(923.35 KiB) Not downloaded yet
