Problems converting Haar Cascade
WolleSmith
Postby WolleSmith » Mon Aug 21, 2017 4:13 am
Hey there,
I created my first haar cascade using opencv 2. The generated XML file works fine. When I try to convert the file however I get error messsages. The converted file also crashes the openmv cam after a couple of milliseconds. I´ll attach two screenshots and the cascade file. Could it be a problem that I used LBP featureType instead of Haar featureType when generating the opencv XML file?
Thank you very much in advance!
opencv.xml
(287.59 KiB) Downloaded 30 times
openmv crash.JPG (55.25 KiB) Viewed 411 times
Conversion errors.JPG (92.8 KiB) Viewed 411 times
Re: Problems converting Haar Cascade
Postby iabdalkader » Mon Aug 21, 2017 11:36 am
Hi, only Haar cascades are supported. Note some users reported the converter doesn't work on Windows.
