I started playing around with the modes some more along with adjusting for banding. Here is a test sketch. May help.
# Find Line Segments Example
# This example shows off how to find line segments in the image. For each line object
# found in the image a line object is returned which includes the line's rotation.
# Note: Line detection is done by using the Hough Transform:
# http://en.wikipedia.org/wiki/Hough_transform
# Please read about it above for more information on what `theta` and `rho` are.
enable_lens_corr = True # turn on for straighter lines...
import sensor, image, time
sensor.set_pixformat(sensor.RGB565) # grayscale is faster
def light_mode_auto():
#sensor.__write_reg(addr, reg&mask)
sensor.__write_reg(0x13, 0xff) #AWB off
sensor.__write_reg(0x0e, 0x65)
sensor.__write_reg(0x2d, 0x00)
sensor.__write_reg(0x2e, 0x00)
sensor.__write_reg(0x22, 0x89); #60Hz banding filter
sensor.__write_reg(0x23, 0x03); #4 step for 60hz
def light_mode_home():
sensor.__write_reg(0x13, 0xfd) #AWB off
sensor.__write_reg(0x01, 0x96)
sensor.__write_reg(0x02, 0x40)
sensor.__write_reg(0x22, 0x7f); #60Hz banding filter
def light_mode_night():
sensor.__write_reg(0x13, 0xff) #AWB on
sensor.__write_reg(0x0e, 0xe5)
sensor.__write_reg(0x11, 0x03);
def light_mode_cloudy():
sensor.__write_reg(0x01, 0x58)
sensor.__write_reg(0x02, 0x60)
def light_mode_office():
sensor.__write_reg(0x13, 0xfd);
sensor.__write_reg(0x01, 0x84);
sensor.__write_reg(0x02, 0x4c);
sensor.__write_reg(0x0e, 0x65);
sensor.__write_reg(0x2d, 0x00);
#sensor.set_auto_gain(False)
#sensor.set_auto_exposure(False)
light_mode_auto()
# All lines also have `x1()`, `y1()`, `x2()`, and `y2()` methods to get their end-points
# and a `line()` method to get all the above as one 4 value tuple for `draw_line()`.
if enable_lens_corr: img.lens_corr(1.8, 1.0) # for 2.8mm lens...
# `threshold` controls how many lines in the image are found. Only lines with
# edge difference magnitude sums greater than `threshold` are detected...
# More about `threshold` - each pixel in the image contributes a magnitude value
# to a line. The sum of all contributions is the magintude for that line. Then
# when lines are merged their magnitudes are added togheter. Note that `threshold`
# filters out lines with low magnitudes before merging. To see the magnitude of
# un-merged lines set `theta_margin` and `rho_margin` to 0...
# `theta_margin` and `rho_margin` control merging similar lines. If two lines
# theta and rho value differences are less than the margins then they are merged.
# Setting both the above to zero will greatly increase segment detection at the
# cost of a lot of FPS. This is because when less lines are merged more pixels
# are tested... which takes longer but covers more possibilities...
# `segment_threshold` controls line segment extraction. It's a threshold on the
# magnitude response per pixel under an infinite line. Pixels with a magnitude
# above threshold are added to the line segment.
# `find_line_segments` merges detected lines that are no more than 5 pixels apart
# and no more than 15 degrees different to create nice continous line segments.
for l in img.find_line_segments(threshold = 800, theta_margin = 15, rho_margin = 15, segment_threshold = 100):
img.draw_line(l.line(), color = (255, 0, 0))
# print(l)
print("FPS %f" % clock.fps())
Cheers
Mike
