Hello!
I have been using this camera as it seems quite fast for what I need to do, which is tracking something really fast and measuring rotation, size and position.
I am trying to use the hough transform find_lines code, along with the frame differencing and find blobs to do this, but I keep having trouble with the lines from the find_lines always jumping around. Is there a way to mitigate this, as I thought running the find lines after I identified a non- moving blob would make the find_lines move less frequently?
I may be doing this wrong with the find_lines, but any help with what technique would be fastest would be a huge help. I also have the PixyCam, which can track objects at the speed I am looking for, but I was hoping this might be a bit more professional and able to be tweaked more than that camera and the find lines was brilliant, but has a lot of noise.
I have my code below if you would like to take a look and run it for yourselves, but I would be really appreciative of any amount of help you could give me on this matter:
import sensor, image, pyb, os, time
sensor.set_pixformat(sensor.GRAYSCALE) # or sensor.GRAYSCALE
sensor.set_framesize(sensor.QQVGA) # or sensor.QQVGA (or others)
sensor.skip_frames(time = 2000) # Let new settings take affect.
sensor.set_auto_whitebal(True) # Turn off white balance.
clock = time.clock() # Tracks FPS.
min_degree = 0
max_degree = 179
if not "temp" in os.listdir(): os.mkdir("temp") # Make a temp directory
kernel_size = 1 # kernel width = (size*2)+1, kernel height = (size*2)+1
kernel = [-1, -1, -1,\
-1, +3, -1,\
-1, -1, -1]
print("About to save background image...")
sensor.skip_frames(time = 2000) # Give the user time to get ready.
sensor.snapshot().save("temp/bg.bmp")
print("Saved background image - Now frame differencing!")
clock.tick() # Track elapsed milliseconds between snapshots().
img.difference("temp/bg.bmp");
thresholds = (245, 255)
# Run the kernel on every pixel of the image.
img.morph(kernel_size, kernel)
img.find_blobs([thresholds], pixels_threshold=100, area_threshold=100, merge=True);
# Replace the image with the "abs(NEW-OLD)" frame difference.
#img.difference("temp/bg.bmp")
#print(clock.fps()) # Note: Your OpenMV Cam runs about half as fast while
# connected to your computer. The FPS should increase once disconnected.
for l in img.find_lines(threshold = 1000, theta_margin = 25, rho_margin = 25):
if (min_degree <= l.theta()) and (l.theta() <= max_degree):
img.draw_line(l.line(), color = (255, 0, 0))
print(l)
