Wifi board issue
I’m trying to setup wifi board using the mjpeg_streamer_1.py program.
Appears to connect fine, but then I immediately get a ‘-6’ error. What is that error?
MicroPython v1.8-4345-g3a2670b on 2016-11-03; OPENMV2 with STM32F427
Type “help()” for more information.
Trying to connect… (may take a while)…
[-58, 2, ‘ASUS’, ‘f8:f0:05:f7:5a:8b’, ‘192.168.1.93’]
Waiting for connections…
6
-6
socket error: -6
socket error: -6
Hi, that was an error with an old firmware version and such. Please update the IDE and your firmware version. In particular, you need to change a line in the streamer script.
That was it! Thank you for the quick response.
Will the M7 improve the fps? I’m only getting about 2.5fps when I go QVGA/RGB565.
Somewhat. But, you should be able to get a lot higher than 2.5 FPS with the M4. So… this means the WiFi is just a bottleneck. Not sure how to test what the problem is.
