implement own Haar-Cascade
augur4u
Re: implement own Haar-Cascade
Postby augur4u » Tue Oct 23, 2018 7:43 am
Hi iabdalkader,
I tried to use your cascade_convert.py to convert haarcascade_frontalcatface.xml but always failed. and I don't know why.
could you help me convert it?
Thanks a ton!
Postby iabdalkader » Tue Oct 23, 2018 7:48 pm
Hi iabdalkader,
Thanks a ton!
Hi, please see the older replies to this thread. The script only works on Linux (for some reason) and it only supports the most basic Haar cascade (using the old format). If you're having a different issue with the script please post the command you used and the error messages.
augur4u
Postby augur4u » Wed Oct 24, 2018 11:59 am
Hi iabdalkader,
Thanks a ton!
Hi iabdalkader,
thank you so much for your quick response and help!
Yes, I read and tried all the older replies but I can't find any right solution. I used Python 2.7.5 and 2.7.13 to run cascade_convert.py to convert but both of them did not work. Can you help me convert it? Please find haarcascade_frontalcatface.xml attached. Thank you so much.
I am looking forward to hearing back from you.
haarcascade_frontalcatface.zip
(241.14 KiB) Downloaded 124 times
Postby iabdalkader » Wed Oct 24, 2018 3:08 pm
Hi iabdalkader,
Thanks a ton!
Hi iabdalkader,
Hi, as I already mentioned a few times, the script only works on **Linux** Not Windows.
augur4u
Postby augur4u » Thu Oct 25, 2018 4:06 am
Hi iabdalkader,
Hi iabdalkader,
Thank you so much. Unfortunately I have no Linux so I hope you can help me convert it if you have time. Thanks a ton.
Postby iabdalkader » Thu Oct 25, 2018 1:20 pm
Hi iabdalkader,
I tried to convert it but this file is a web page, seems you downloaded it from github, you need to download the raw xml file.
augur4u
Postby augur4u » Fri Oct 26, 2018 7:14 am
Hi iabdalkader,
Hi iabdalkader,
Thank you so much for your help.
Now I downloaded the raw xml file from https://raw.githubusercontent.com/openc ... atface.xml.
right?
haarcascade_frontalcatface-ok.xml
(401.75 KiB) Downloaded 141 times
Looking forward to your converting for me. Thanks a ton.
Postby iabdalkader » Fri Oct 26, 2018 7:23 am
Attached.
In the future please use a Linux VM to convert cascades, I'll get around to fixing the script on Windows.
haarcascade_frontalcatface-ok.cascade.zip
(11.52 KiB) Downloaded 113 times
augur4u
Postby augur4u » Fri Oct 26, 2018 8:33 pm
Attached.
Dear iabdalkader,
Thank you so much for your help and suggestion.
I will install Linux VM to convert cascades and also look forward to your fixing the script on Windows.
Thank you again.
Best regards.
Mars
Postby Mars » Fri Nov 30, 2018 7:05 am
Hi:
The oemnv is great open vision library. Lately i apply it on some my research project.but i want to train my own cascade classfier.i train face_cascade.xml can detect face on opencv.
Howecer,i use openmv_casscade.py convert to face.cascade can not detect face on openmv.May you help me .Thank you very much.
Hrer is my cascade.xml.
cascade.xml
(39.87 KiB) Downloaded 110 times
Postby iabdalkader » Fri Nov 30, 2018 12:22 pm
Hi, please see the replies to this thread. The script runs on Linux, and only supports simple Haar cascades (the old format) and the output (*.cascade) needs to be copied to flash or SD.
