pcls1026
Postby pcls1026 » Thu Mar 26, 2020 7:45 pm
I finally got logged in under my wife's name.
Ihave enclosed my script file. I want the image to appear on the IDE frame buffer screen "immediately" after the picture is taken on line 24 , before the rest of the code is run.
Jim
pcls1026
Re: image
Postby pcls1026 » Thu Mar 26, 2020 7:59 pm
I forgot the enclosure.
blksearch.py
(11.22 KiB) Downloaded 19 times
Re: image
Postby kwagyeman » Thu Mar 26, 2020 9:31 pm
Hi, do sensor.flush().
When you call snapshot() it flushed the frame buffer by jpeg compressing it and then putting that in a jpeg buffer the IDE can pull later asynchronously. Then snapshot grabs the next image from the camera. Flush just does the first part above.
Note that the IDE still grabs the image asynchronously... so, if you script terminates you need to add like a 1 second wait after flush so the IDE has time to grab the image. For your case you just need to add flush.
pcls1026
Re: image
Postby pcls1026 » Sun Mar 29, 2020 2:34 pm
I got my image timing to work the way I wanted. Thanks
MY script works the way I want, when it is running in the IDE. What do I need to do to run it NOT using the IDE. I assume I need a power supply. How do I program the camera uP with the script. And, does the uP start running automatically when power is turned on. As you can tell I'm somewhat of a novice.
Jim
Re: image
Postby kwagyeman » Sun Mar 29, 2020 2:44 pm
Tools->Save Script to OpenMV Cam.
pcls1026
Re: image
Postby pcls1026 » Sun Mar 29, 2020 3:55 pm
after i'v saved the script to the cam, is it non volitile?
how do I start the program running, or does it just start when I power up the cam?
Re: image
Postby kwagyeman » Sun Mar 29, 2020 6:19 pm
It will run at startup. Main.py runs at startup. The blinking blue light is a main.py script on the camera when it's fresh.
pcls1026
Re: image
Postby pcls1026 » Sun Mar 29, 2020 6:32 pm
I'll try it and get back.
Jim
pcls1026
Re: image
Postby pcls1026 » Sun Mar 29, 2020 6:39 pm
Under tools in the IDE the copy .. command is not high lighted.
Jim
Re: image
Postby kwagyeman » Sun Mar 29, 2020 7:38 pm
Connect to the camera first.
pcls1026
Re: image
Postby pcls1026 » Mon Mar 30, 2020 3:18 pm
I need a new usd card. I broke my old one. How many GB should I buy?
Jim
Re: image
Postby kwagyeman » Mon Mar 30, 2020 5:47 pm
Doesn't really matter unless you plan to fill it up. Please avoid over 32 GB as the camera doesn't do SDXC.
pcls1026
Re: image
Postby pcls1026 » Fri Apr 03, 2020 5:48 pm
Once my script is loaded onto the uSD I want to run the script on a different power source (batteries) than the PC. To What pins on the cam7 do I connect the Voltage and ground from my power source. Also what voltage do I use , i.e. 5V or 3.25 V?
Jim
PS: When are the OpenMV Cam H7 plus coming.
Re: image
Postby kwagyeman » Sat Apr 04, 2020 12:11 pm
You connect 4v-6v on VIN and GND. The OpenMV Cam Plus is shipping now. Driver work is not fully yet completed for it however so the performance is not as high as it should be yet but it's functional.
pcls1026
Re: image
Postby pcls1026 » Sat Apr 04, 2020 6:54 pm
thanks
Ill close this one.
Jim
