OpenMV doesnt recognise my CAM H7
shen
Postby shen » Sat Mar 07, 2020 2:49 am
Hi everybody,
I tried to start a new "hello-world" project this time using the OpenMV IDE.
I am afraid that my camera is now bricked. the details are as follows:
1. I use a data and voltage uUSB (I checked it!)
2. when i plug it to the computer device manager doesnt even refresh :(
3. when i do the shortening of RST and BOOT trick, device manager recognise it as a DFU in FS Mode rather than STM bootloader.
4. OpenMV hardware doesnt succeed rebooting it since it does not recognise it.
I hope somebody might help, thank you!
Re: OpenMV doesnt recognise my CAM H7
Postby kwagyeman » Sat Mar 07, 2020 3:03 am
Do you get a green light still when you plug it into the PC. Or is it fully dead? No lights? Since you get something when you do the DFU trick it should be fixable.
shen
Postby shen » Sat Mar 07, 2020 9:51 am
Hi Nyamekye,
thanks for your reply, unfortunately when i plug it in i see no led at all and OpenMV IDE doesnt recognise it.
so i used a jumper to connect BOOT0 and RST, and then reconnect it to the usb port, this time i see my device in "device manager as DFU, however the DFU trick doesnt work in the IDE.
hope i was clear enough.
Postby kwagyeman » Sat Mar 07, 2020 11:55 am
Okay, the DFU trick in the IDE is the only way to fix it. Can you Elaborate what doesn't work? If possible, you you use Windows? The DFU for windows is better than on Mac and Linux.
shen
Postby shen » Sat Mar 07, 2020 3:37 pm
I'd like to share a short video of the problem with you if it's ok.
Send me a 'hi' email to the address: shenhavo@post.bgu.ac.il, and i'll send it to you.
Thanks again,
Shenhav
Postby kwagyeman » Sat Mar 07, 2020 6:01 pm
shen
Postby shen » Sun Mar 08, 2020 12:56 am
For some reason i got a response mail which says that i spam your email :(
so i attach here a shareable link so everyone can see:
fisrt case: regular connection - no device manager response.
https://tinyurl.com/rcloqmq
second case: DFU connection - device manager recognize it, however nothing happens in IDE
https://tinyurl.com/rjrg8o5
Postby kwagyeman » Sun Mar 08, 2020 6:14 pm
Okay, it should be recoverable. DFU might just not detect the camera... Sigh...
Download this program here: https://www.st.com/en/development-tools ... eprog.html
The install the attached file (unzip first)
openmv.zip
(1.17 MiB) Downloaded 75 times
Postby kwagyeman » Sun Mar 08, 2020 6:16 pm
We use an ST DFU tool which might be outdated now that ST switched to a different DFU tool. We will have a new version of the IDE come out with new DFU support using another program.
shen
Postby shen » Thu Mar 12, 2020 3:34 am
Hi again,
So ST programmer doesnt accept DFU files as input, so i used https://www.st.com/en/development-tools ... 32080.html this application to convert DFU->Hex
then i downloaded it in DFU mode and it seems that it work.
thank you!
Users browsing this forum: No registered users and 15 guests
