How to send an image across serial port and not interrupt other output or kill frame rate?
Plaba
Postby Plaba » Wed Mar 04, 2020 6:11 pm
Hello! I'm rather new to OpenMV, and I'm writing a Java application that connects to the OpenMV by a serial port.
I noticed that the OpenMV IDE was capable of receiving both the frames that the OpenMV captured, and at the same time receiving the uninterrupted output of the program. What would I need to do to replicate that behavior between a Java application and the OpenMV?
Re: How to send an image across serial port and not interrupt other output or kill frame rate?
Postby iabdalkader » Wed Mar 04, 2020 7:41 pm
You need to port this:
https://github.com/openmv/openmv/blob/m ... yopenmv.py
And there's an example that uses that module to execute a script and read the framebuffer:
https://github.com/openmv/openmv/blob/m ... enmv_fb.py
Plaba
Postby Plaba » Wed Mar 04, 2020 10:25 pm
Thanks for your reply!
I've already ported the script to Java. It's available at https://github.com/entech281/JOpenMV.
My problem is that I need to use the serial port for other data as well. What would I need to do not have the frame data and the other data print at the same time and get mixed together?
Postby kwagyeman » Thu Mar 05, 2020 12:12 am
Hi, this uses the debug mode so they are already not mixed.
Plaba
Postby Plaba » Fri Mar 06, 2020 2:49 pm
Thanks a lot!
After a little digging, I figured out that I need to use the tx_buf API call to read the output of the program.
Thanks for your help!
Postby iabdalkader » Fri Mar 06, 2020 5:02 pm
Yes that's right, you just need the tx_buf_len and tx_buf commands.
Users browsing this forum: No registered users and 21 guests
