External Interrupt Send
Isperia
Postby Isperia » Thu Feb 27, 2020 11:32 am
Hi!
Is there any limit on what functions can be called on an ExtInt callback? my code specifically involves sending an array over I2C on a pin getting pulled low
here's the code:
import sensor, image, time, math, ustruct
import pyb
from pyb import UART
#if switch on:
#    enemycolor = blue
#else:
#    enemycolor = yellow
fieldwidth = 200
fieldheight = 300
blobdev = 10 # how far blobs are allowed to deviate
BLUE_REGION = (135, 220, 30, 10)
YELLOW_REGION = (135, 65, 30, 10)
blobsx = []
blobsy = []
def absloc():
    mone = tan(180-goal1())
    mtwo = tan(goal2()-180)
    return fieldheight/(mone+mtwo), ((fieldheight/(mone+mtwo)*mone)+150)
def angletoenemy():
    return atan(blob.cy(), blob.cx())
def thresholds(r,g,b, pm=20, ):
    l, a, b = image.rgb_to_lab((r, g, b))
    return ((l-pm, l+pm, a-pm, a+pm, b-pm, b+pm))
def I2CSend(out):
    text = str(out) + "\n"
    data = ustruct.pack("<%ds" % len(text), text)
        bus.send(ustruct.pack("<h", len(data)), timeout=70) # Send the len first (16-bits), original was 10000
            bus.send(data, timeout=70) # Send the data second.
            print("Sent Data!") # Only reached on no error.
        except OSError as err:
            pass # Don't care about errors - so pass.
            # Note that there are 3 possible errors. A timeout error, a general purpose error, or
            # a busy error. The error codes are 116, 5, 16 respectively for "err.arg[0]".
def callback(line):
    print("line =", line)
    I2CSend([blobsx, blobsy])
bus = pyb.I2C(2, pyb.I2C.SLAVE, addr=0x12)
bus.deinit() # Fully reset I2C device...
print("Waiting for Arduino...")
kancho = 0
extint = pyb.ExtInt('P7', pyb.ExtInt.IRQ_FALLING, pyb.Pin.PULL_NONE, callback)
sensor.set_auto_exposure(True)
sensor.set_auto_whitebal(True)
sensor.set_auto_gain(True)
bluecall = img.get_statistics(roi = BLUE_REGION)
print("found the blue")
blue = [bluecall.l_mode(), bluecall.a_mode(), bluecall.b_mode()]
yellowcall = img.get_statistics(roi = YELLOW_REGION)
print("found the yellow")
LMode_Y = yellowcall.l_mode()
LMode_B = bluecall.l_mode()
AMode_Y = yellowcall.a_mode()
AMode_B = bluecall.l_mode()
BMode_Y = yellowcall.b_mode()
BMode_B = bluecall.l_mode()
yellow = [
    ((LMode_Y + blobdev), (LMode_Y - blobdev), (AMode_Y + blobdev), (AMode_Y - blobdev), (BMode_Y + blobdev), (BMode_Y - blobdev))
blue = [
    ((LMode_B + blobdev), (LMode_B - blobdev), (AMode_B + blobdev), (AMode_B - blobdev), (BMode_B + blobdev), (BMode_B - blobdev))
sensor.set_auto_exposure(False)
sensor.set_auto_gain(False)
thresholds = [
    yellow[0],              # generic_red_thresholds
    blue[0],                # generic_green_thresholds
    (0, 30, 0, 64, -128, 0) # ???
    blobsx = []
    blobsy = []
    for blob in img.find_blobs(thresholds, pixels_threshold=200, area_threshold=200, merge=True): #add rotation to determine orientation
        if blob.elongation() > 0.5:
            img.draw_line(blob.major_axis_line(), color=(0,255,0))
            img.draw_line(blob.minor_axis_line(), color=(0,0,255))
        blobsx.append(blob.cx())
        blobsy.append(blob.cy())
    img.draw_rectangle(BLUE_REGION)
    img.draw_rectangle(YELLOW_REGION)
I run the code, and have fixed the global variable errors. However, the I2C function doesn't seem to be calling.
Thanks!
edit: nevermind, it's throwing uncaught MemoryError exceptions
Users browsing this forum: Bing [Bot] and 5 guests
