is it possible to do something else during adc reading ?
chrisPyres66
Postby chrisPyres66 » Tue Jan 21, 2020 3:14 am
Dear all,
i try to sample an analog signal at 40khz with adc but i dont success to do it in real time in this code :
import time, pyb
from pyb import ADC
adc = pyb.ADC(pyb.Pin("P6"))        # create an ADC on pin P5
tim = pyb.Timer(6, freq=40000)         # create a timer running at 10Hz
buf = bytearray(5)                # creat a buffer to store the samples
    # The ADC has 12-bits of resolution for 4096 values.
    print("----------")
    adc.read_timed(buf, tim)            # sample here
    i=1
    for val in buf:                     # loop over all values
        print(i, val)                      # print the value out
        i=i+1
    time.sleep(1000)
because i cant do anything else when adc.read_timed(buf, tim) is working.
Do you have another way to do this ?
Re: is it possible to do something else during adc reading ?
Postby iabdalkader » Tue Feb 04, 2020 7:12 am
That's not how this function works, it reads n samples and then returns. If you want to do something else while sampling the closest you can get is sampling in a timer callback.
Users browsing this forum: MSN [Bot] and 11 guests
