Problem running usb_vcp.py code.
danopenMV
Postby danopenMV » Mon Jan 13, 2020 5:35 am
Hello.
I have been trying to establish a connection between my openMV M7 camera and a raspberry pi 3 B+ model.
I used the following code, found in the openMV github repo.
https://github.com/openmv/openmv/blob/m ... sb_vcp.py
I currently encounter this error:
Re: Problem running usb_vcp.py code.
Postby kwagyeman » Mon Jan 13, 2020 3:46 pm
That looks like no data was received and then you Ctrl+c the script.
danopenMV
Postby danopenMV » Tue Jan 14, 2020 2:15 am
Hey! Thanks for the reply.
You're spot on with your analysis.
I saved the script as main.py on the camera.
Thereafter I ran the commented script on my raspberry pi. Are there any probable reasons for this to occur?
Postby kwagyeman » Wed Jan 15, 2020 1:34 am
Yes, a couple of things can happen. 1st, what serial port name does your OpenMV Cam appear as? The script we gave as an example expects a certain serial port name.
Other than that... Can you verify the main.py script on the camera is the example script and was saved to the camera as main.py? Please check after a power cycle of the camera.
danopenMV
Postby danopenMV » Fri Jan 17, 2020 4:59 am
Hello. Thanks for your replies.
The problem suddenly went away, I am not exactly sure how it did.
So I have progressed on with my work.
Currently, I am trying to coordinate a robot arm with your camera.
I have integrated the usb_vcp code with the Single Color RGB565 Blob Tracking Example to send out the following parameters: blob.cx(), blob.cy().
I use the same receive code used on usb_vcp, modified for integer transmission.
Even though, the coordinates do get passed on, I have encountered a number of problems:
1. a lot of garbage values are transmitted. (to overcome this, I filtered them using the frame size dimensions)
2. the receiving side stops receiving data after a while.
Is there a way to completely eliminate garbage transmission. My knowledge on the serial communication protocols being used here is rather limited.
This is the code running on the camara.
This is the code I have on the receiving end
Filtered output with correct details
Raw output with garbage
Postby kwagyeman » Fri Jan 17, 2020 11:22 am
Can you post the code in non screen shot form?
danopenMV
Postby danopenMV » Fri Jan 17, 2020 10:27 pm
Code running on camera
import sensor, image, time, math, pyb, ustruct
from pyb import USB_VCP
#def blobDetails(blobInput, xMin, xMax, yMin, yMax):
led = pyb.LED(1) # Red LED = 1, Green LED = 2, Blue LED = 3, IR LEDs = 4.
# Creat usb virtual communication port.
usb = USB_VCP()
# Switch on red led to indicate program is running
led.on()
        print(clock.tick())
        if blob.elongation() > 0.5:
            img.draw_line(blob.major_axis_line(), color=(0,255,0))
            img.draw_line(blob.minor_axis_line(), color=(0,0,255))
        print("blob rectangle ", blob.rect())
        print("blob center.", blob.cx(), blob.cy())
        cmd = usb.recv(4, timeout=5000)
        if (cmd == b'snap'):
            usb.send(ustruct.pack("<II", blob.cx(), blob.cy()))
Code running on receiving side(raspberry pi 3 b+)
#!/usr/bin/env python2.7
import sys, serial, struct
port = '/dev/ttyACM0'
sp = serial.Serial(port, baudrate=115200, bytesize=serial.EIGHTBITS, parity=serial.PARITY_NONE,
             xonxoff=False, rtscts=False, stopbits=serial.STOPBITS_ONE, timeout=None, dsrdtr=True)
sp.setDTR(True) # dsrdtr is ignored on Windows.
    sp.write("snap")
    sp.flush()
    sentData = struct.unpack('<II', sp.read(8))
    # Raw output.
    '''print("X coordinate: {0}, Y coordinate: {1}".format(sentData[0], sentData[1]))'''
    # Filter garbage.
    if ((sentData[0] > -1) and (sentData[0] < 320)):
        if ((sentData[1] > -1) and (sentData[1] < 240)):
sp.close()
Postby iabdalkader » Sat Jan 18, 2020 11:19 am
Hi, just remove all the print() statements and the code will work as expected, you can't print while using USB VCP, all that output goes through USB as well.
Postby kwagyeman » Sat Jan 18, 2020 2:33 pm
For clarification, we only have one USB link to the PC. Print and the vcp send method do effectively the same thing and both use the same pipe.
If you'd like to make your code more flexible If recommend just using the print method only and USB vcp read method.
Then, in the desktop code just parse lines of text and ignore lines that don't start with like a certain character combo.
danopenMV
Postby danopenMV » Sat Jan 18, 2020 11:05 pm
I am not in the lab right now, it is the weekend. I have no way to test the code out anymore.
The knowledge youy guys have is incredible.
Does this method of communication enable full duplex communication?
Postby kwagyeman » Sun Jan 19, 2020 11:40 am
Yes, it's full duplex. The fifo buffer on the OpenMV Cam can receive about 512 bytes before running out of space.
Users browsing this forum: MSN [Bot] and 7 guests
