Flashing green forever - Cannot connect
Joe100A
Postby Joe100A » Sun Jan 12, 2020 5:49 am
After following the prompt to update to new firmware today I can no longer connect to the openmv. Whenever I connect to usb with ide on Win10 it just keeps flashing free . If I try to connect a dialog window saying “connecting (hit cancel of this takes more than 5 seconds) keeps popping up and going away. Finally , Timeout error while getting firmware version dialog appears.
Re: Flashing green forever - Cannot connect
Postby kwagyeman » Sun Jan 12, 2020 10:38 am
Hi, this means the firmware update failed. The bootloader is running repeatedly over and over again.
That said, you should be able to reflash the camera by clicking connect on the ide when the camera is not connected, plug the camera in when prompted, and then it should relfash it and be good again.
Users browsing this forum: MSN [Bot] and 9 guests
