pixels in centimeters
ali
Postby ali » Wed Jan 08, 2020 5:19 am
I tried to use the blob.h and blob.w commands to determine the edge length of a square.
I think that he gives me the edge length in pixels but I need it in cm, can I convert it or is there a command that outputs it directly in cm?
Re: pixels in centimeters
Postby kwagyeman » Wed Jan 08, 2020 11:53 am
The camera has no way to know what the size of the object is. You have to write code that converts pixels to mm using a scaling method. It should be a linear scale for your object so just measure how many pixels equals how many cm and multiply the pixels by that ratio.
Users browsing this forum: MSN [Bot] and 4 guests
