Accessing extra_fb's pixels
IAmCoder
Postby IAmCoder » Sun Jan 05, 2020 3:00 pm
I am trying to compare two images. When I try to access the pixels from extra_fb, the device crashes / restarts. I can access the pixels from img just fine. Do I need to do anything to arg_msk so I can access the pixels?
extra_fb = sensor.alloc_extra_fb(sensor.width(), sensor.height(), sensor.GRAYSCALE)
    diff2 = img.difference2(extra_fb)
    extra_fb.replace(sensor.snapshot())
    print(clock.fps(), diff2)
static mp_obj_t py_image_difference2(uint n_args, const mp_obj_t *args, mp_map_t *kw_args)
    image_t *arg_img = py_helper_arg_to_image_mutable(args[0]);
    image_t *arg_msk =
        py_helper_keyword_to_image_mutable_mask(n_args, args, 2, kw_args);
    fb_alloc_mark();
    int pixels = 0;
    for (int y = 0, yy = arg_img->h; y < yy; y++) {
        uint8_t *row_ptr1 = IMAGE_COMPUTE_GRAYSCALE_PIXEL_ROW_PTR(arg_img, y);
        uint8_t *row_ptr2 = IMAGE_COMPUTE_GRAYSCALE_PIXEL_ROW_PTR(arg_msk, y);
        for (int x = 0, xx = arg_img->w; x < xx; x++) {
            int pixel1 = IMAGE_GET_GRAYSCALE_PIXEL_FAST(row_ptr1, x);
            int pixel2 = IMAGE_GET_GRAYSCALE_PIXEL_FAST(row_ptr2, x);
            // works
            if (pixel1 >= 32) {
                pixels++;
            // crashes when uncommented
            /*if (pixel2 >= 32) {
                pixels++;
    fb_alloc_free_till_mark();
    return mp_obj_new_int(pixels);
Re: Accessing extra_fb's pixels
Postby kwagyeman » Mon Jan 06, 2020 12:44 am
image_t *arg_msk =
Is probably NULL. I think the 2 should be a 1. Or, pass mask=extra_fb in your python code.
IAmCoder
Postby IAmCoder » Mon Jan 06, 2020 1:58 pm
Elite, changing it to 1 worked, thanks!
Users browsing this forum: MSN [Bot] and 5 guests
