View real time coordinates
GiusB
Postby GiusB » Wed Dec 18, 2019 4:26 am
I'm using OpenMV from a week and I would view at screen in real time two point that I track and print on terminal (blob.cx(), blob.cy()).
How can I do?
This is the code:
# Single Color Code Tracking Example
thresholds_index = 0 #for green
# The below thresholds track in general green things.
thresholds = [(30, 100, -64, -8, -32, 32)] # generic_green_thresholds
sensor.set_framesize(sensor.QVGA) #320x240
sensor.skip_frames(30)
# camera resolution. "merge=True" must be set to merge overlapping color blobs for color codes.
for blob in img.find_blobs([thresholds[thresholds_index]], pixels_threshold=200, area_threshold=200, merge=True):
print("x:", blob.cx(), end='')
print(" y:", blob.cy())
Thanks in advance!
Re: View real time coordinates
Postby kwagyeman » Thu Dec 19, 2019 11:49 am
Hi, are you trying to view that point on your computer or on our LCD display?
