help!
scspenc
help!
Postby scspenc » Sat Dec 07, 2019 1:16 am
Hi I am new to micropython and the open MV cam h7. I am attempting to control a motor when a color threshold is detected. I attached my code, can you tell me if I am going down the right path?
# Multi Color Blob Tracking Example
# This example shows off multi color blob tracking using the OpenMV Cam.
# The below thresholds track in general red/green things. You may wish to tune them...
thresholds = [(34, 54, 90, 45, 48, -116), # generic_red_thresholds
(0, 15, 0, 40, -80, -20)] # generic_blue_thresholds
# You may pass up to 16 thresholds above. However, it's not really possible to segment any
# scene with 16 thresholds before color thresholds start to overlap heavily.
# camera resolution. Don't set "merge=True" becuase that will merge blobs which we don't want here.
counter = 0
StartTime = clock
EndTime = clock + clock.tick(1000)
for blob in img.find_blobs(thresholds, pixels_threshold=200, area_threshold=200):
if blob.elongation() > 0.5:
img.draw_line(blob.major_axis_line(), color=(0,255,0))
img.draw_line(blob.minor_axis_line(), color=(0,0,255))
# Adds to Counter to show that a Rectangle was Drawn.
if counter >= 30: # Turn off Motors.
if clock.tick() == 1000:
# Code for Motors to turnoff
if blob.color == blob.red()
# Code for sorting to the red chute
if blob.color == blob.blue()
# Code for sorting to the blue chute
if blob.color == blob.green()
# Code for sorting to the green chute
Re: help!
Postby kwagyeman » Sat Dec 07, 2019 4:37 pm
Hi, please use the code tags when posting. Also, this is not valid OpenMV Cam code:
Anyway, please ask a specific question. You basically are just asking folks to do your application when you ask if you are on the right path and not a specific question. Post like this are starting to come in everyday now and I might start not to reply them them much anymore.
scspenc
Re: help!
Postby scspenc » Wed Dec 11, 2019 3:58 pm
My apologies. I didnt mean to upset you. I figured it out! Thank you for replying. I appreciate your time!
Re: help!
Postby kwagyeman » Wed Dec 11, 2019 6:20 pm
You didn't, glad you got it working.
Users browsing this forum: MSN [Bot] and 5 guests
