Debug build fails on v3.5.0
xvbv
Postby xvbv » Mon Dec 02, 2019 5:40 am
Building the tag v3.5.0 with options: make -j8 DEBUG=1 TARGET=OPENMV4 fails.
See logs attached.
build_debug.log
(21.52 KiB) Downloaded 19 times
Re: Debug build fails on v3.5.0
Postby iabdalkader » Mon Dec 02, 2019 11:59 am
Hi, I fixed this error, and other errors that showed up with DEBUG=1. Note some features have to be disabled to get the debugging image to fit into the flash (it's much bigger than the optimized image), like tensorflow and LAB table for example. Also note you can still debug the optimized image, the debugging image is not really needed.
xvbv
Postby xvbv » Tue Dec 03, 2019 4:04 am
Alright, thanks !
Yes, the image file becomes biiiiig... :)
