pyopenmv support multiple camera
skylin008
Postby skylin008 » Wed Nov 06, 2019 7:21 pm
Hello everyone! I have three opemmv board to detection left/right/up side object. I want to view every side image in pc via USB meantime.Does pyopenmv.py can be finish this function? Thanks advance!
Re: pyopenmv support multiple camera
Postby iabdalkader » Wed Nov 06, 2019 7:45 pm
Someone contributed this script, it supports multiple cameras:
https://github.com/openmv/openmv/blob/m ... v_multi.py
skylin008
Postby skylin008 » Thu Nov 07, 2019 6:43 am
OK.Thanks !@ iabdalkader
skylin008
Postby skylin008 » Tue Nov 12, 2019 2:01 am
Hello iabdalkader! I used the Pyopenmv_multi.Py script On Win10 system and Python2.7 version.But when run the script,Nothing information shows at CMD console or show any Windows. What is issue there?Thanks!
Postby iabdalkader » Tue Nov 12, 2019 9:47 am
I haven't tested these scripts on Windows, I'm not sure if they work on Windows. Please try the script on Linux.
skylin008
Postby skylin008 » Wed Nov 13, 2019 5:01 am
Thanks iabdalkader kindly reply.Today, I Test it at ubuntu 16.04 platfrom and python2.7.12.Nothing information show same as win10 system.Can you be try at your linux system?Thanks!
sudo python pyopenmv_multi.py /dev/ttyACM0 test.py
Postby iabdalkader » Wed Nov 13, 2019 5:10 pm
What information do you expect to see ? It just runs test.py. What is in test.py ?
skylin008
Postby skylin008 » Wed Nov 13, 2019 7:12 pm
Thanks iabdalkader ! The test.py as follow:
 import sensor, image, time
    clock.tick()                    # Update the FPS clock.
    print(clock.fps())              # Note: OpenMV Cam runs about half as fast when connected
I had installed three openmv4 at pc, want to showing the three image information same time, needed the function same as pyopenmv_fb.py script. Thanks!
Postby iabdalkader » Thu Nov 14, 2019 10:58 am
It's working, but it only runs the script for 250ms and then tries to read the text buffer if there's any output, so you won't always see output. This is just the test mode, you should import this module and write your own script if you want to run scripts and wait for output, read the framebuffer etc..
