Lepton functionality with OpenMV
jubi5312
Postby jubi5312 » Mon Oct 07, 2019 8:49 pm
I am working on an Infrared camera project using FLIR lepton and I am hoping to start with OpenMV FLIR kits. I had few queries to clear before the purchase,
Is FLIR lepton 3.5, 160x120 compatible with OpenMV?
I wanted to know if the pan tilt shield is compatible with PhantomX Robot Turret Kit. It comes with a ArbotiX robocontroller. Can this be integrated with the OpenMV Lepton functions?
Can the WiFi shield be used to transmit data from OpenMV remotely to PC?
I needed to detect humans using IR camera. I know OpenMV has already created a neutral network that detects this. How are the radiometric measurement parameters of the FLIR Lepton set? Is this separately done
through Lepton sdk or OpenMV IDE?
I also needed to capture infrared images at timed intervals using the OpenmV flir kit? Is this possible using OpenMV?
Kindly advice.
Jubin
208-892-4265
Re: Lepton functionality with OpenMV
Postby kwagyeman » Tue Oct 08, 2019 12:06 am
Yes, the FLIR Lepton 3.5 works with it. All of them do.
I don't know if our pan tilt shield is compatible with the kit you mentioned.
All your questions are a general yes. When asking details please make an effort to Google documentation we have already written on these things. We have a large API and example code that answers most of your questions.
For detecting people, just use blob detection with the FLIR. There's no need for a CNN. You just set the temperature you are looking for to what the human temperature is and you are good.
jubi5312
Postby jubi5312 » Fri Oct 11, 2019 12:16 pm
Thank you.
Postby kwagyeman » Fri Oct 11, 2019 12:38 pm
Please see the examples in OpenMV IDE. You can set the target tracking temperature easily.
Users browsing this forum: MSN [Bot] and 3 guests
