connect as serial or sd card
When I connect the newly acquired openmv board, it opens up a sdcard (like on a phone). I was expecting it to be a serial port.
Running Linux Mint 18, 64bit. (similar to ubuntu).
Should I add rules to udev and if so, suggestions?
Dmesg shows:
sd 16:0:0:0: [sdb] Attached SCSI removable disk
[61003.119068] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[61189.000595] usb 3-1: USB disconnect, device number 126
[61189.000689] cdc_acm 3-1:1.0: failed to set dtr/rts
[61189.303810] usb 3-1: new full-speed USB device number 127 using xhci_hcd
[61189.437003] usb 3-1: New USB device found, idVendor=1209, idProduct=abd1
[61189.437007] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[61189.437008] usb 3-1: Product: OpenMV Virtual Comm Port in FS Mode
[61189.437010] usb 3-1: Manufacturer: OpenMV
[61189.437011] usb 3-1: SerialNumber: 000000000011
[61189.437523] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
[61189.657704] usb 3-1: USB disconnect, device number 127
[61189.657819] cdc_acm 3-1:1.0: failed to set dtr/rts
[61190.207822] usb 3-1: new full-speed USB device number 7 using xhci_hcd
[61190.337083] usb 3-1: New USB device found, idVendor=1209, idProduct=abd1
[61190.337086] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[61190.337088] usb 3-1: Product: OpenMV Virtual Comm Port in FS Mode
[61190.337089] usb 3-1: Manufacturer: OpenMV
[61190.337090] usb 3-1: SerialNumber: 000000000011
[61190.337619] cdc_acm 3-1:1.0: ttyACM0: USB ACM device
[61190.337866] usb-storage 3-1:1.2: USB Mass Storage device detected
[61190.338019] scsi host17: usb-storage 3-1:1.2
[61191.336206] scsi 17:0:0:0: Direct-Access     uPy      microSD Flash    1.00 PQ: 0 ANSI: 2
[61191.336497] sd 17:0:0:0: Attached scsi generic sg2 type 0
[61191.336653] sd 17:0:0:0: [sdb] 97 512-byte logical blocks: (49.7 kB/48.5 KiB)
[61191.336780] sd 17:0:0:0: [sdb] Write Protect is off
[61191.336782] sd 17:0:0:0: [sdb] Mode Sense: 00 00 00 00
[61191.336948] sd 17:0:0:0: [sdb] Asking for cache data failed
[61191.336950] sd 17:0:0:0: [sdb] Assuming drive cache: write through
[61191.342311]  sdb: sdb1
[61191.343314] sd 17:0:0:0: [sdb] Attached SCSI removable disk
[61191.478740] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
should I be worrying about the failed to set dtr/rts?
You should see a USB can serial port appear. It also comes up as an SD card too.
Ibrahim, any thoughts?
You should see both, a mass storage device and CDC. Here’s my dmesg:
[  498.774299] usb 1-1.2: new full-speed USB device number 6 using ehci-pci
[  498.877266] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
[  498.878393] usbcore: registered new interface driver cdc_acm
[  498.878398] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[  499.098643] usb 1-1.2: USB disconnect, device number 6
[  499.540975] usb 1-1.2: new full-speed USB device number 7 using ehci-pci
[  499.631728] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
[  499.653973] usb-storage 1-1.2:1.2: USB Mass Storage device detected
[  499.654353] scsi host6: usb-storage 1-1.2:1.2
[  499.654475] usbcore: registered new interface driver usb-storage
[  499.656115] usbcore: registered new interface driver uas
[  500.659555] scsi 6:0:0:0: Direct-Access     uPy      microSD Flash    1.00 PQ: 0 ANSI: 2
[  500.662247] sd 6:0:0:0: [sdb] 352 512-byte logical blocks: (180 kB/176 KiB)
[  500.663142] sd 6:0:0:0: [sdb] Write Protect is off
[  500.663152] sd 6:0:0:0: [sdb] Mode Sense: 00 00 00 00
[  500.664043] sd 6:0:0:0: [sdb] Asking for cache data failed
[  500.664052] sd 6:0:0:0: [sdb] Assuming drive cache: write through
[  500.675948]  sdb: sdb1
[  500.681509] sd 6:0:0:0: [sdb] Attached SCSI removable disk
[  500.872983] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Thanks, I do get both. Was getting confused by the ide not connecting.
I can connect with arduino and type some python commands. ide want’s to update firmware but can’t seem to do it, so I’m stuck at that point.
Just install the firmware development environment. Then you can use the dfu script to flash the device:
Note: Skip installing the udev rules. The new IDE doesn’t need them.
