Camera settings of a program that recognizes both color and circle
merlin
Postby merlin » Sat Jul 20, 2019 1:49 pm
I tried to identify color block and circles in one program at the same time. image.find_circle and image.find_blobs have different settings for the image. The settings for the circle are as follows:
Sensor.set_pixformat(sensor.RGB565) # use RGB565.
Sensor.set_framesize(sensor.QQVGA) # use QQVGA for speed.
Sensor.set_contrast(3)
Sensor.set_gainceiling(16)
After the circle is recognized, the color block settings are as follows:
Sensor.set_framesize(sensor.QVGA) # use QQVGA for speed.
Sensor.set_auto_whitebal(False)
But when it recognized the circle after color block recognition, I found that the color of the image is abnormal, I think
is the reason, What do I do to get this working?
Re: Camera settings of a program that recognizes both color and circle
Postby iabdalkader » Sat Jul 20, 2019 8:20 pm
When you change the settings the sensor needs time to adjust and settle down, you could either skip some frames
 sensor.skip_frames(100)
to skip 100 frames or
 sensor.skip_frames(time=300)
to skip frames for 300ms or you could keep the settings the same (maybe use set_windowing to reduce the frame).
merlin
Postby merlin » Sat Jul 20, 2019 9:14 pm
I tried it, but failed. The color of the image is abnormal when it recognize the color after recognizing the circle. I think I should change contrast and gainceiling to the default parameter using
Sensor.set_contrast(default parameter)
Sensor.set_gainceiling(default parameter)
but I don't know what the parameters are?
Postby iabdalkader » Sat Jul 20, 2019 9:17 pm
abnormal how ? can you post a screenshot ?
merlin
Postby merlin » Sat Jul 20, 2019 9:26 pm
P2 is the picture that identifies the circle
P1 is an abnormal picture when recognizing colors
Postby kwagyeman » Sat Jul 20, 2019 11:06 pm
Hi, you need to turn auto white balance off immediately. It changes the color of the image when the picture isn't staring at a complex scene. So, before the skip frames call turn auto white balance off using the set_auto_whitebalance() method.
merlin
Postby merlin » Sun Jul 21, 2019 11:22 am
I tried , but it did not work too
Postby kwagyeman » Sun Jul 21, 2019 12:20 pm
Okay, I don't really understand the problem you having then. The images look okay. Can you be more detailed?
