First time with servos not going well
ScottM
Postby ScottM » Tue Jul 16, 2019 3:33 pm
I am trying to get two servos to work with the pan/tilt shield, but so far it isn't working. I am brand new to Micropython, so it might be a learning issue. Here is what I did.
I connected a 5.2Vdc power supply to the servo bat pins and confirmed that it carries through to the Vin and GND pins.
I connected two HS-5485HB digital standard servos.
I connected the shield to the OpenMV camera and made sure to test it first by running the helloworld example. The camera works fine
From the examples, I opened pca9685.py and under Tools/Save open script to OpenMV cam. It asks if I want to strip comments and convert spaces to tabs, so I say Yes
I then open servo.py and do the same thing
I then select Tools, Reset OpenMV Cam
I then open main.py and hit the green arrow to run it.
I get an error "OSError:[Error 110] ETIMEDOUT
Nothing happens. I was expecting the servos to move. What do I do to get this working?
Scott
ScottM
Re: First time with servos not going well
Postby ScottM » Tue Jul 16, 2019 3:46 pm
I tried again with one of those tiny pan/tilt kits, but I get the same error.
Postby kwagyeman » Tue Jul 16, 2019 11:28 pm
Hi Scott, the drive you are trying to use is for controlling the 8-channel servo shield. You have the Pan/Tilt shield. For this shield no driver chip is necessary. The servos are directly controlled by the OpenMV Cam. Please see the Board Control -> Servo example for how to drive servos directly from the H7 main chip using it's PWM output.
ScottM
Postby ScottM » Wed Jul 17, 2019 8:58 am
Thanks Nyamekye,
That sample works perfectly and is a lot simpler. Perhaps you can update the comments in the other sample to make it clearer to users which code works for the servo shield vs the pan/tilt shield. On to my next learning challenge. This is fun.
Scott
Postby kwagyeman » Wed Jul 17, 2019 1:47 pm
I can probably comment on this on the product page.
