image areas analyse
chrisPyres66
image areas analyse
Postby chrisPyres66 » Thu Jun 06, 2019 12:12 pm
Dear all,
I try to analysesome areas of the image but i am not sure if i do it well because my results are not what i expected.
For exemple, i created a bmp image, as i did it for masking, with the background at value 0x00 and an area in the middle with 0xFF value.
I tried to do an AND boolean operation with this image in this python code :
import sensor, image
sensor.set_windowing((170,65,330,171))
sensor.skip_frames(time=1000)
   sensor.snapshot().b_and("OK.bmp")
but the result is not an sensor image with only the desired area but an Black and white dotted image ...
What do i missed please ?
ps: i can attached the bmp image due to invalid extension file...
Re: image areas analyse
Postby iabdalkader » Thu Jun 06, 2019 12:58 pm
Hi, use pgm for now there seems to be a bug in bmp code.
Postby iabdalkader » Sun Sep 08, 2019 8:03 pm
Hi, this bug has been fixed.
Users browsing this forum: MSN [Bot] and 12 guests
